MOT and Integrated Taillights
Discussion in 'General 1000RR Discussion' started by CBRgus, Jan 16, 2012.
  1. dan.1moore1
    My bike looks way better with out the indicators and tail tidy
    Personal preference thou
  2. Mel
    Mel Active Member
    on the last MOT with the R6 my OH got told that if indicators are fitted they must work, if it has none its fine apparently... ??
  3. arthurbikemad
    Think you will find if they are fitted as standard then you need them (you may change for other), if they are not fitted it should fail. Bikes older than 1986 are under a different law and they can be removed if fitted but again if are fitted they must work and flash at proper rate. Space apart is not listed as MOT directive. Trials and MX bike are again different law and do not need indicators. (last time I looked..lol)
  4. Mel
    Mel Active Member
    yeah thats what i thought, i think our MOT man was well known for 'looking the other way' lol
  5. arthurbikemad
    lol, I K N O W what you mean..... :D
  6. dan.1moore1
    Mine certainly is
    He passed my 600 with a Two Brothers slip on with no baffle installed ( V loud ) and he also passed my dads BMW with a decat exhaust ! lol
    He asks if the BMW had a cat normally , said yes with worry and he said " No probs " . Top man i say ha ha
  7. CBRgus
    CBRgus Active Member
    Wow! This forum got a lot more attention than I thought it would off a simple question :D . Thanks for all the inputs, I found some minature turn lamps last night for $40. I also ordered some wire harness so that I wouldn't have to modify the original wire harness. Stevebetts, I was rereading what I put and yes that would be a huge rearend...LOL. Haggler, I do have integrated lights on the front and you had said something about a baffle for the Zorst exhaust. Is that something that you can install or do I need to purchase a new muffler? Just before I get laughed off a forum, I have owned the CBR1KRR for about 2 weeks and before that I owned a Suzuki Seca II 600 in 1997 (for about a year), so I don't have much experience with motorcycles :( , but I am learning quick :D . What is the funny thing is that I was going to ask about the exhaust becuase I ran past a buddies house in 2nd @ 2500 rpms and he said that it woke him up. One last thing, the red reflectors do they have to be a certain size or will two little that hold on the license plate work (Chris Products Bolt-On Reflectors - Cruiser Motorcycle - Motorcycle Superstore)? Once again thanks for all the help/comments, I will get some pictures when I get home tonight and get them posted!.
    Gus
  8. Nutty Tart
    Nutty Tart Well-Known Member
    Yup those little ones are fine ... I have those same ones on my scoot
  9. CBRgus
    Sorry guys, weather has been crappy here last couple of days. When the sun comes out I will snap some pictures.
  10. Haggler ®™
    Haggler ®™ Active Member
    I think you only need 1 little red reflector at the rear,but make sure the number plate is the correct size,a MOT tester is more likly to turn a blind eye on other things if he see,s that you,ve made an effort .
  11. dave d
    dave d Elite Member
    more of an issue might be your headlight mate we drive on the left bud..
  12. dan.1moore1
    That is a sweet ass !! lol Is the license plate holder custom ?
  13. Nutty Tart
    Well it was a shop bought alloy bracket ... then I threw most of it away and only used the bare minimum part .
    Then I stuck an R&G numberplate light directly on the plate .
    So yup I suppose its custom :p
  14. CBRgus
    I didn't even think about the headlight...my left side illuminates on low beam and both with high beam. The UK bikes are different than this?
  15. dave d
    dave d Elite Member
    its the direction of the beam gus it may dazzle oncoming traffic.
    never ridden in europe can anyone advise how you go on do you get those blanking strips like for car headlights?
    #35 dave d, Jan 21, 2012
  16. Haggler ®™
    This is a bodge......................but I,ve been doing it for years and it works !!
    1.Remove lefthand bulb 2.With a set of Tinsnips remove the locating tags around the bulb. 3. Re-insert into leadlamp,switch on showing beam patten on a wall.4. rotate bulb at the same time looking at the pattern on the wall,as it is rotated the upper cut image will rotate,turn untill the beam image shows the upper cut to the left.Sometimes its not possible to get a correct pattern but near enough for MOT.If you want to try it before you cut the tags,release the bulb,pull it out a bit and rotate.
  17. CBRgus
    Finally a decent day here are some pictures of the ride :D
    I added the miniature turn lamps and a plate lamp. I will think about getting the integrated tail light when I get settled in over there :D
    Also, someone mentioned about getting the correct UK plate size??? Are there different sizes? All the US plates are the same size as seen in the above picture.
    Gus
  18. Nutty Tart
    Nice one Gus ...... some nice subtle mods :cool:
  19. ray
    ray Well-Known Member
