No you are right cruise is on motorway is at a lower TP%, though I've never been able to measure it (need to get one of those DJ POD gadgets!). No reason not to go lower. I used this thread when I produced my map using an AT. http://www.hondacb1000r.com/forums/dynojet-uk/8931-how-autotune.html#post115755
Well the tuner has modified the existing map from 4000rpm to 6000rpm ... Across all TP... So I will be trying that out once the map switch arrives... Those who use the DJ map switch where have you located it?
When I get my PCV+AT fully set up gonna get one of these. http://www.ebay.co.uk/itm/MONITOR-D...2?pt=LH_DefaultDomain_186&hash=item4ae15b5e44 I know probably a waste of cash, but I love data/information!
Your as bad as me Slick, I'm getting one too, be easy to do runs at each throttle postion held perfect and record the data. Also when it hesitates I can read the screen and see what's happening. Love gadgets.
With all the sensors connected and with logging you really analyse whats going on, adjust and perfect your map. Best bit is when analysing the data at work peeps will actually think I am worrking on client data
