My RR4 Build thread
Discussion in 'Pictures & Videos' started by Chris.93, Oct 15, 2015.
  1. SimonRR
    SimonRR God Like
    to be fair though mine was mostly unsed on track, were uneeded top end speed gearing is wasted acceleration :D
  2. Chris.93
    Chris.93 Member
    Fair enough then, I'll be at donny end of April, so get to see how it is then!
  3. derchef
    derchef Well-Known Member
    was in uk 16-40 oem ratio aswell?
  4. ColinBR
    Same hoses I have on my track bike mate. Really feel good and a few others have used them and say they are excellent.
  5. Chris.93
    Chris.93 Member
    Yep :)
  6. Chris.93
    Chris.93 Member
    Yeah they're great for the price, I had to trim a couple down a couple of cm's to fit better, but happy to do that and save the £140 over samcos!
  7. racman
    racman Active Member
    how much was the bazazz kit chris, and what does it incorporate?
  8. SimonRR
    SimonRR God Like
    yes 04-05 were 16f 40r were as 06-07 were 16f 42r
  9. Chris.93
    Chris.93 Member
    Hiya, was £250+ postage from ukracesupport.
    It's just a fuel module, like a power commander, but goes to both primary and secondary injectors (pc5 would also need a secondary module to do this) and has capability to have two maps put on it. Is also adjustable every 250rpm to a pc5's 500rpm :)
  10. raphael
    raphael Elite Member
    got a link for those hoses please fella?
  11. Chris.93
    Chris.93 Member
    • Thanks Thanks x 2
  12. exuptoy
    exuptoy Elite Member
    I got a ZFi unit off here for my 09 for £125. Keep your eyes open here and ebay.
  13. Chris.93
    Chris.93 Member
    That's a good deal!
  14. arthurbikemad
    PCV maps each 250rpm, the SFM give full control over secondary injectors Bazzaz does not. PCV also has two maps. :)
  15. Chris.93
    Chris.93 Member
    Ah my bad then, was just going off what I'd been told :)
  16. arthurbikemad
    None of it matters, mapping is mapping, PC whatever is just the tool.. Nice bike.
  17. exuptoy
    I'm sure when I fitted the ZFi it had a set of injector plugs for the upper and lower injectors. Can't remember just now as I have previously fitted a PCIII too so may be wrong.
  18. arthurbikemad
    It does, but the software works out the fuelling, unlike the SFM where you can control the injectors individually if required and add up to 250% more fuel, also they can be mapped for each gear giving a total of 48 maps. (not including Autotune)
    #78 arthurbikemad, Mar 16, 2016
  19. exuptoy
    I didn't know that. The only thing with DJ is they seem to be like Apple in that you have to pay for everything extra! It can get silly expensive by the time you've added the SFM, QS module, ignition control, etc etc
  20. arthurbikemad
    Not wrong, mapping the uppers gives no more power on a stock motor (side by side charts look the same), it does give a better rider experience on some bikes like the 10r and s1.
    Nowt wrong with Bazzaz, great system.
