My Winter Project :-)
Discussion in 'Mods, Upgrades, Accessories and Products' started by lambchops, Sep 15, 2013.
  1. lambchops
    lambchops Elite Member
    Well checked the valve shims, all within spec phew but only just.. Inles is between 0.16 and 0.03 in the manual mine were 0.15 on most so just within.. Will need doing next winter :)
  2. sinewave
    Why not adjust them to a mid way point whilst you had em open so to speak?
  3. lambchops
    Yes I did think about doing that Sinewave, not sure I want to start stripping the cams out though.. I guess you dont know what size shim you need until you open it up and see whats installed?
    Also after I did the valves made up one PAIR blanking plate, will have to do the other tomorrow as took ages hehe
    Also start putting some of the hoses on it
  4. JimGreen
    JimGreen Active Member
    Bliiiiiiiiiiiiiiing
  5. lambchops
    Thanks Jim :)
  6. sps170373
    Looking like it won't be long before the first test ride mate!
  7. martinowen
    Is it not worth doing now if will need doing next winter? As the engines out already
  8. lambchops
    Thanks chaps :) yes Martin I know you speak sence... Will have a look what's involved.
    On another note aqua blasting is in hand, the guys asked me if any of the covers are magnesium.. Don't think so are they?
  9. JimGreen
    John - Huge Honda Service Manual (2008 - 2013) arrived this morning, so if you need anything give me a shout.
    Jim
  10. lambchops
    Thanks Jim :) I do have the RR4 one here so should be allright I think.. Will read up on the adjustment section and see how tricky it is.. I had a skim yesterday and involves lifting cams etc so look very scary :eek:
  11. hump333
    hump333 Member
    Yes I think there is magnesium in casing to make them stronger under heat. LC. It put in everything nowadays
  12. lambchops
    Thanks hump, yes found out the real details now. For those thats are intersted on the rr4 / 5 rocker, sump and sprocket cover are mag and on the rr6 the alturnator cover is also.. Makes you wonder why they didn't go the whole hog and do the clutch side also!
  13. raphael
    raphael Elite Member
    that looks lovely on its own mate!
  14. lambchops
    Thanks Raphael :)
    Well started work on my new remote water res, made a template out of thin board to get the sizing correct. All clears the swinging arm but is close! Going to add a couple of those external site glass levels to the left side and a nice aeroquip fitting to the rear to plumb to the rad. Going to have a go cutting out the alloy myself then just taking it somewhere to get welded up
  15. Skippy79
    Skippy79 Active Member
    why don't you just use a bottle at the front of your fairings like they do on race bikes? easier, more room and they make the bike go faster ;)
  16. lambchops
    That's plan b skippy if this goes to shit :) been cutting out the alloy tonight so will have it in pieces shortly
  17. lambchops
  18. derchef
    derchef Well-Known Member
  19. lambchops
    Well engine casings and yoke have been posted off this morning to Vapour Blast UK in Norfolk, been speaking to Phil there and very impressed with the service so far! Looking forward to seeing the finish on these as it’s a much more gentle process than bead blasting as its done in water and leaves the alloy a nice sheen polished look which I will just protect with AF50.
    Will post pics of course when I get then back
    There details are here if anyone is interested in having anything done Vapour Blasting UK
  20. lambchops
    OK more news :) have arranged whats being carbon dipped with Wicked coatings Wicked Coatings | Hydrographics & Carbon Dipping Specialist These parts are going off for the carbon fibre treatment, its an interesting process dipping the part in water then adding a very thin film of carbon sheet, pull the item out through the sheeting and hey presto a very good carbon look. They then paint the part in 2 pack clear to seal it.
    having these parts done
    I would get real carbon fairing inserts but you just cant buy them anymore :(
