My Winter Project :-)
Discussion in 'Mods, Upgrades, Accessories and Products' started by lambchops, Sep 15, 2013.
  1. lambchops
    lambchops Elite Member
    Just emailed david Silver and Webmoto..
    What do you mean Gilesey cant picture it?
  2. lambchops
    ok well have the main gasket at David Silver so have ordered that one.. just need the upper one now and the injector orings..
  3. Gilesy
    Gilesy Elite Member
  4. lambchops
    Ah with you Gilesy, may have to use that for the upper gasket..
  5. Gilesy
    Gilesy Elite Member
    Just cut it with a Stanley knife to the correct width.. The thickness will probably be fine..
  6. lambchops
    Will give it a try cheers :)
  7. lambchops
    Just had an email from Wicked coatings, parts are ready!! Heres a couple of them
    #607 lambchops, Feb 27, 2014
  8. Repsol Rob
    Repsol Rob Elite Member
    Don't mean to be nosey................ but what do you pay for that ? Looks brilliant by the way.......
  9. lambchops
    They did me a real good deal Rob for a mention in the mag, I think I gave them 5 / 6 items in the end and it was £85 including postage back to me.. He said that was around a 50% discount though.. Send them some pics of what you want doing and they will quote you. He said pics dont do the bits justice so cant wait to see them!!
  10. Repsol Rob
    Certainly looks good in the pics mate.......... cant wait for the first press of the engine....................
  11. Skippy79
    Skippy79 Active Member
    that looks epic, think that the bike is slowly coming together..... I'll have to see the baby IRL one day, maybe in may when I'm at cadwell ;)
  12. Gilesy
    Gilesy Elite Member
    Looks fantastic Lambchops.. you know my fetish with Carbon and coudnt wait to see the finished products..
  13. lambchops
    Thanks guys, does look real in the pics doesnt it!
    OK well need some help chaps, connected all the electrics tonight to see if the fuel pump would prime and it wouldnt :(
    Turned bike on all lights came on etc no warning lights, no fuel pump prime sound, turned the kill switch to run and the engine warning light came on. now if I press the starter very lightly it started to try and turn over but without fuel pump prime something is wrong... I put a meter accross the fuel pump wiring as there is no voltage where they should be for a short burst so the manual says.
    Now I dont have an exhaust servo motor connected so im not sure if the warning light could be due to this.. I also dont have a tilt sensor plugged in but it has been shorted with a piece of wire haha, not sure if this works or not though... Any suggestions?
    should the engine warning light come on when exhaust server is disconnected?
    what should I try next?
  14. lambchops
    Well done a quick google and found some other things to check, fuel pump relays etc.. Think I better order a tilt sensor anyway as dont want to run without one!
    Dam close to trying to start it now!! ordering oil etc tonight :)
  15. Skippy79
    tilt sensor you can shorten by connecting the 2 outer wires( believe there are 3, was on the 09 blade ) have a check to see if this is correct, cause if it is then you can cancel out that one...
    otherwise I'm no use with electrics so no use to you, sorry buddy
  16. lambchops
    thanks Skippy, yes two outer wires is whats been shorted..
    OK, will check the relays and stuff, im worried as im not running the HISS ECU but have the HISS connector on the loom could be an issue... Need to do some research on this one, perhaps short some wires together etc..
    Just a case of working through stuff.
    #616 lambchops, Feb 27, 2014
  17. Gilesy
    Gilesy Elite Member
    Lambchops - I got the warning light on when I was removing the servo motor from my bike (before putting a few resistors) so I think thats quite normal..
  18. lambchops
    Ok great news Gilesy, need to buy a servo blank device anyone know where I can get one?
  19. Gilesy
    Gilesy Elite Member
    I can make you one if you like.. do you still have the old servo motor?
  20. lambchops
    Càn you? Wow. No don't have a motor but willing to cut off the loom side connetor and solder directly? Would be amazing if you could matey :)
