Good news, you will not be disapointed at all. Just make sure you take your time and as you take the old panels off, remove the clips & grommets etc to put onto your new panel. and another tip, use your std infills rather than the ones that come with the kit, you'll find everything will fit a lot better. When fitting the kit start with the rear seat Tank cover Belly pan Nose fairing Side panels Mudguard. Hope this helps...
