No oil on Dipstick
Discussion in 'Maintenance' started by Franbot, May 1, 2019.
  1. nigelrb
    True, but some of my analogies employ a bit of poetic licence.:)
  2. Franbot
    Franbot Active Member
    Hahaha :D
    Thanks for your concern Nigel but I have calmed down and haven't sold my bike or topped myself you'll be glad to know.
  3. bonjo
    bonjo Active Member
    from no mark to full mark it only takes around 200ml so it is not much. But the low oil pressure light would suggest you have quite a bit less. But still enough to lubricate the engine but not enough to help with cooling. I always put 2.8L after an oil+filter change to give me 60% level on the dipstick.
    Very interesting, I assumed MFL meant max fluid level and looking at nigel's photo holding the dipper correctly to read it, the max line is to the right of it. The end of the dipper is the minimum level I guess.
  4. nigelrb
    Correct. Merely a warning to the owner: 'Hey, I need more oil.'
    I'd actually painted similar marks on my wife's inner thighs.:eek::)
  5. Demmel
    Demmel Member
    • Useful Useful x 2
  6. bonjo
    bonjo Active Member
    be carefull with that picture. Those quantties are for dry engine (no oil whatsoever) or a rebuilt one: i.e the first fill
    The service quantities are 2.8 & 3.
    I have seen in various forums people making the mistake of using 3.7L for an oil change; no wonder the poor engine was drowned in it and burnt it! I suspect this was the culprit behind some RR8's oil buring problem
  7. Jez
    Jez Senior Member
    If you look at 2 stroke engines they have a sniff of oil on the bearings and bore mixed with the fuel and work ok
    They would be more than happy with 2.2 lts :D
    • Agree Agree x 2
  8. Jez
    Jez Senior Member
    Being from Yorkshire it breaks my heart doing an oil change when it is at the top of the dipstick :)
    • Funny Funny x 2
  9. Cream_Revenge
    Cream_Revenge Active Member
    It's fucked. I'll give you £500 and I'm doing you a favour!
    • Funny Funny x 2
  10. Jez
    Jez Senior Member
    Dont listen to this conman, I am sure I could fix it for £450
