non OEM oil filter
Discussion in 'Maintenance' started by bonjo, Feb 17, 2023.
  1. Jez
    Jez Senior Member
    I think the problems are with the ones with the nut that leak
  2. bazzashadow
    bazzashadow Elite Member
    I heard the welds break on them
  3. Coda
    Coda Active Member
    Yeah I’ve done a bit of reading, and it seems that it’s the spot welds on the nut that is the problem, possibly due to people using a spanner to install the filter. Which is what I think I did on the 748 :(
    I’m going to be ordering a couple of hiflo’s in a minute.
  4. bazzashadow
    Just drain the oil, change the filter and pour the same back with a top up.
    At least the filter media doesn’t break down
    • Agree Agree x 2
  5. CharlieR85
    CharlieR85 Elite Member
    K&N issued a recall on certain serial numbers of oil filters, I remember checking mine.
    https://www.knfilters.com/recallkn204
    If you've used the nut to torque it down though it could be worth changing it anyway.
  6. Coda
    Coda Active Member
    Being a Ducati desmo you probably don’t know this is an important step:
    3. Filter the metally bits out of the oil. 4. Put the oil back in the engine which is now 27g lighter.
    :eek::D
    • Funny Funny x 2
  7. bonjo
    bonjo Active Member
    like coda mentioned, the pot weld on the nut is the weak point.
    I also read some people torque the filter using the nut and it splits. The nut is for removing the filter only.
    My preference is for those without the nut just to avoid this issue
