Overrun noise - fast metallic whirring sound?
Discussion in 'Maintenance' started by Dougie M, Aug 8, 2012.
  1. arthurbikemad
    lol knew it :) Too loose is always better than too tight, with my punters race bikes they get run slack as a c#ck in a sock! Expech at CW Park!
  2. Dougie M
    Dougie M Active Member
    next question - how the hell do I change my fecking picture on this thing!
  3. kpone
    Interesting...As a recent convert to the Wurth dry chain lube, which comes massively recommended but does require a bit of a leap of faith as when you use it, it doesn't look like there's any lube on it at all, I noticed a lot more transmission noise, which I put down to the final drive not being slathered in noise suppressing gloop for the first time since I got it.
    Dougie, if you mean changing your Avatar, go to 'settings' on the top right and then 'edit Avatar' on the left sidebar.
  4. arthurbikemad
    520 kits make more vibes too, also rearsets and the likes of aftermarket wheels with smaller cush drive rubbers all add up to more vibe and noise, same as non OEM sprokets as they also do away with the front cush drive sproket that costs a bomb from Mr H!
  5. HRCTrev09
    HRCTrev09 Well-Known Member
    Hiday doody Dougie welcome to the forum mate :) About time u came into the fold!
    Some off the guys have already heard of you due to your accident! Blaming myself I had a good old rant about the dangers of farkin about with your suspension that night!
    Anyhoo welcome aboard mate! They are a great crowd on here enjoy your stay buddy! :D
  6. Dougie M
    cheers man! - now i just need to work out how to get my bike blurb at the bottom of my posts!
  7. Dougie M
    right lets see if that worked...
  8. Dougie M
    Hi mate - so the noise is back again - but at slightly higher speed after slackening off the chain. I should add its brand new and even tho i slackend it off, maybe i havnt done it enough..when sitting on the bike it would be more tension on the chain right?
    Its also worth noting I have a renthal sproket at the back its quite thin and i can move the chain from side to side slightly....could that be whats making the noise?? Its booked in on sat but thought ide ask!
    D
