Paddock Stand Recommendations please?
Discussion in 'Mods, Upgrades, Accessories and Products' started by nigelrb, Apr 24, 2018.
  1. bonjo
    bonjo Active Member
    interested to know how you are getting on with the front stand. Did they charge for delivery (didn't see any mention of it on their site!)
  2. nigelrb
    Hi Bonj!
    No delivery charge because of value ordered.
    Erm, front stand is a long story:(. I haven't used it, or at least I haven't been able to use it. My front drive is on a slight downward angle with no level area. There is no problem, of course, with using the rear stand with the bike facing 'uphill'. But when I attempted to use the front stand the lift felt a bit unstable. Part of this is the angle, the other part is that the driveway is brick paved, so the stand's wheels won't roll in a smooth action. The remedy is to slide a thin sheet of plywood under the wheel so the stand can roll freely. But I have not done that. Sorry I can't help with positive news.
    Compounding the problem is that I live on my own, so there's no available second-person assistance available. I had intended to throw a 'residential offer' to esteemed member @ Lozzy, but with all the benefits of living with moi, the deal-breaker would be that there's no room for her bike!!:D:D
    • Funny Funny x 2
  3. DazK
    DazK Active Member
    Seconded :)
  4. bonjo
    bonjo Active Member
    thanks nige. I can fully understand the issues of non horizontal and non smooth surfaces for paddock stands. I gather putting the front on a stand is a wobbly affair to start with!
    BTW If you have an abba stand, most of the weight is off the front tyre; they also do a front lift adapter for it.
  5. Lozzy
    Wouldn't need it any more would I :rolleyes:
    ...not with 7 sets of keys on tap every morning...:D
    • Funny Funny x 2
  6. nigelrb
    Yep, I have the ABBA with front lift. My SP2 is presently hibernating on it:).
  7. bazzashadow
    bazzashadow Elite Member
    I brought the same stands and the rear is perfect but the front is easy to do but it does feel a bit wobberly when on it and I am not sure if it looks like it’s twisting.
    #47 bazzashadow, Dec 12, 2018
  8. Selmer50mark
    Selmer50mark God Like
  9. nigelrb
    Yep, the under triple clamp lift is probably the best and easiest going!
  10. bazzashadow
    Thinking of getting a front clamp stand like the one inSelmer50mark picture but what I want to know is what size pin fits the blade? And can I take the front wheel out without removing the brake callipers?
  11. Selmer50mark
    got this from ghostbikes.com , based in Preston, it came with a selection of pins , just under £50 .I did have to bend the horn bracket up a bit on my RR7 to clear the top section . No you can't take out the wheel without removing the brake callipers. 5065-Black-Pro-Range-B5065-Front-Head-Stand-1600-0.jpg don't take this the wrong way but you need to lift the rear first with a stand ;), I've seen people try to lift just the front :eek:
    #51 Selmer50mark, Jan 6, 2019
  12. bazzashadow
    @Selmer50mark
    Thanks for that
    I have read about having the rear stand on and m and p have got them for £40 but I just wondered if the pins where the right size
    Thanks
  13. Selmer50mark
    Comes with
    13 mm
    15 mm
    16.5 mm
    17 mm
    18 mm without looking I can't remember what I use , but one of them is the right fit for an RR7 , i will check it out tomorrow and let ya know . The adjustable height is handy too
  14. Selmer50mark
  15. raphael
    raphael Elite Member
    You have to undo the calipers to get the wheel out no matter what stand you use
    • Agree Agree x 2
  16. Boothman
    Boothman Elite Member
    I know where to come if i need to borrow one now :D
  17. nigelrb
    And, you'd get a good meal at the same time!!:)
  18. bazzashadow
    Cheers for that
    But now I know you still have to remove the callipers I’m not sure if I need one:(
    On my VTR I did pull the thread on one of my callipers so my mate heli coiled it and I had no more problems but thats the reason I did not want to remove the callipers
  19. ray
    ray Well-Known Member
    Iain said:
    Once you have tried a Harris stand, I don't thing anything else compares!
    Read the same thing in the 360 degree garage section in the Aug issue of PB
  20. ray
