Power Commander 5 - ABS
Discussion in 'Mods, Upgrades, Accessories and Products' started by BladeHRC, Jul 12, 2011.
  1. Jamiestrada
    It was the akropovic map which contained the scorpion map :), they told me to use the yoshi map as it is the closest map to the akrapovic until I get a custom map done
  2. dan.1moore1
    Ah yes,my mistake, I remembered a map was wrong but thought it was the yosh map. Cheers Jamie. Well out of ideas now about bladeHRC's bike running lumpy. The PCV done wonders for mine but every bike is different.
  3. Jamiestrada
    I know what you mean about the PCV, my bike is smooth as you like now with just a generic map.
    Really improved things for me, thiink once I get it mapped it will be even better if thats possible :high5:
  4. dan.1moore1
    Yeah a custom map is next on my list. Hopfully a Yoshi R77 that i ordered last week is going to be delivered tomorrow so ill get it done then.
  5. BladeHRC
    BladeHRC Active Member
    Just looked at the maps on the CD and there arent half as many maps on the CD as on the website. These two for example are not on the disk...
    M16-002-507 Yoshimura slip-on exhaust with baffle, Stock or aftermarket air filter, Dynojet O2 eliminator fitted
    M16-002-508 Yoshimura slip-on exhaust, Stock or aftermarket air filter, Dynojet O2 eliminator fitted
    Anyone tried the above?
    Weather is starting to close in here on the west coast of Mid Wales :-(
  6. dan.1moore1
    Its just started raining in Swansea. My yoshi R77 should be delivered today so ill be trying the maps tomorrow seeing as it looks like a wet weekend. ill report back
  7. Jamiestrada
    I am using the 508 map, however, I have a Akrapovic slip on, this is the best I could do from Dynojet, it is very smooth though :)
  8. BladeHRC
    I'm going to load up the 508 map today, but might not get a chance to try it out. What made you try the 508 map with the Akra? ... or were you just going through them all to see which worked?
  9. Jamiestrada
    Dynojet told me to use the 508 they said it was the closest to the akrapovic set up, because the akrapovic map actually contains a scopion map (they messed up).
    It does seem very well suited though. Still getting a custom map when I get some cash spare which may be some time at this rate :sad:
  10. BladeHRC
    Didnt get round to putting the 508 map on but will do tomorrow between the Moto GP & BSB races! :)
    Does your Akra have a baffle and cat?
  11. Jamiestrada
    No Cat and baffle removed :)
  12. BladeHRC
    I put the 508 map on, but if anything it's worse than the other map IMHO! Tick over and low revs is horrible. Maybe that's just how it is when you remove the cat and power valve and have an open exhaust?
    Someone said theirs run better with the DB killer in, so I suppose I better get one to try. Otherwise its a dyno session for peace of mind, which I will probably do anyway even if the DB killer helps smooth things out.
  13. dan.1moore1
    Its a strange 1 is this mate. Your the first person iv heard have problems with the yosh R77. There is people on here running an R77 with out a power commander and say the bike runs lovely.
    Tracking info says mine will be delivered tomorrow so il let you know how i get on with my power commander and the supplied maps on the CD
  14. BladeHRC
    Did you get ur zorst Dan? Must say that ebay listing looks dodgy as hell... but fingers x-ed all's good!
    Maybe it's just me being fussy... but I would definitely say that the bike is more lumpy low down than before any mods. Tick over is not smooth, it constantly goes "brap-brap-brap-brap", even when riding slowly through town its as if its hunting so I'm pulling the clutch in and coasting a little at low speed to smooth it out instead of just driving slowly. Will be interested to see how you get on with urs Dan.
  15. dan.1moore1
    Yeah i got it mate. 200 bucks ... I didnt think he was going to send it but then he sent me tracking info and i was worried it was gonna be wrecked as he didnt put a pic up but its all good and fitted .
    Bit of a fiddle to get it on but iv loaded up the no baffle , O2 eliminator map and so far its ticking over sweet. i havnt taking it out yet but as soon as the roads dry ill update you
