Remember and order a plug for the hole left in the exhaust Sent from my HTC Sensation running Android Revolution HD using Tapatalk
I left my sensor fitted in the exhaust and just ty wrapped the cable up, then fitted the O2 eliminator
What's the crack with MOT Emissions ... Power commanders and no lambda probes? If the emissions tests are that strict ... I suppose in theory you could stand on the doorstep of mot test centre and wind the power commander right down, then reload your map when your all done I suppose as long as its not run for ages and its on and off and not revved hard it shouldn't do any damage Sent from my HTC Sensation running Android Revolution HD using Tapatalk
Well I didn't know that .... Obviously Sent from my HTC Sensation running Android Revolution HD using Tapatalk
Well the Repsol has the most BHP anyway ??? (after the HRC) so you should be ok with a little probe left in there Steve
you are spot on with two most powerful again Jamie! You just need to remember to get the order correct next time!
Yeah, yeah! Steve, if you want a few custom maps to try out (they are with a Yoshi though) just pm me your email addy, and i'll send them across to you. Cheers.
Same here I have a custom for the Akra as well if you want to try it, however I would get it on the dyno and fettled properly as soon as you can, because your bike is special and there is no other quite like it in the world
