Power...power.....POWER!!!!!!
Discussion in 'General 1000RR Discussion' started by BoroRich, Jun 4, 2013.
  1. Slick
    Slick Elite Member
  2. vvtr
    vvtr New Member
    i do a similar mod by cutting a 8x60mm strip of hdpu (plastic bottle top) about 1.5mm thick, take all the slack out of the cables and wiggle it underneath between the cam and cables, then redo the play.
    helps to whack a good dollop of grease in as well while the throttle top housing is off.
    you dont need to remove the cables or tube to do this, just back off the adjusters as much as possible.
    doesnt have to be glued either - in fact imo theres less chance of it jamming if its floating...
    not had one stick open yet and ive done it to all mine and a few mates bikes :)
    on my firestorm & sp1 (before the sp2) i fitted the hrc throttle tubes and found they still werent extreme enough so i still added the plastic spacer... makes them about 1/6th turn and much funner. :D
  3. sinewave
    Go all the way and just fit an on-off switch! :rolleyes:
  4. wedgiewolves#223
    wedgiewolves#223 God Like
    I have Hrc throttle and cables twat to get cable ends on throttle body's but I'm sure the Hrc is 1/6th turn I find it perfect as on my old rr6 . My 12 felt horrible on the throttle compared when I first had it so 21 miles in it was changed .
  5. sinewave
    How many Dollars and how long to fit the HRC gear Wedgie?
  6. vvtr
    vvtr New Member
    makes it easier if you remove the clip-on from the fork, fit the cables to the tb's then pop the clip-on back on :)
    i struggled like fk the first time i did it but like awt else you find the nack the more you do it!
  7. wedgiewolves#223
    Think I paid around £75 took around a hour buddy only because it was first time in there not too bad to be honest mate
  8. wedgiewolves#223
    Loosen clip on spin it towards rear of bike no need to remove clip on easy to get on off just fiddly getting ball ends on cable in a small space but not a drama
  9. wedgiewolves#223
    You can fit a 06 on r6 throttle tube to your normal cables this is what I done on my rr6 blade but you have to shave a bit of metal off the throttle tube housing but I thought my new one deserved better lol .
  10. navvy10
    navvy10 Well-Known Member
    I fitted a PCV, K&N filter and Yoshi can and found the difference fantastic! :D
    I've been advised that carbon wheels is the ultimate performance mod that by far gives the best results, not sure if anyone on here can speak from experience on the difference?
  11. phantom
    phantom Active Member
    yeah heard the R6 mod on the older blades, can it be done on the 08 onward ones?
  12. JM1
    JM1 Active Member
    Yes.
  13. kev.b
    kev.b Well-Known Member
    My 2006 blade felt slow when it was standard , but is bloody quick after I fitted a full Leo Vince Factory system , PC3 an map , Airbox Intake , An K&N filters .
    Standard gearing.
  14. jokeshopbeard
    jokeshopbeard Active Member
    Can't speak from experience, but I've been drooling over them a lot. Got an HRC throttle just begging to be fitted too, but waiting to do PCV, street hooks and new clutch cable all at once - which means about a days work.
