project bandit 650
Discussion in 'Other Bikes' started by Gravel trap, Oct 10, 2020.
  1. Gravel trap
    Gravel trap Elite Member
  2. Gravel trap
  3. Gravel trap
    so I've got some more parts lock set clocks throttle bodies that need dam good clean switch gear front wheel calipers so it's starting to look more like a stripped down bike and less of a ravaged mess.
  4. Gravel trap
  5. Gravel trap
    that decal will go when I paint wheels
  6. Gravel trap
    bit manky but a clean and some braided lines and she should stop. back already has a hel line on it which is nice 20210303_133308.jpg
  7. Gravel trap
    fresh battery and filters of course. didnt realise starter motor was missing when I got it so I've bought a used one too 20210303_133411.jpg
  8. PauloHRC
    PauloHRC God Like
    Get stuck in there lad!! ;)
  9. TheRamJam
    TheRamJam Well-Known Member
    This is coming together nicely.
    Top work there fella.
  10. Gravel trap
    well apart from some missing bolts and changing brake pads ect I think only real big stuff I need now is a seat and the plastics headlamp and time . I need it running asap really want to do some runs on it to test out before the big charity run .
  11. hitch
    hitch Elite Member
    Nowt wrong with them callipers, in fact, I’d suggest adding more oil so the pads glide smoothly over the braking disc surface.
  12. Gravel trap
    yeah I wasent best impressed that the box looked to be dripping in 10/40 a little visit to the parts cleaner will sort them
  13. Gravel trap
    calipers soaking in a bowl of degreaser pistons won't budge so I'm hoping a good soak and clean and I can remove them and freshen up calipers. battery box and battery fitted today along with new spark plugs and coil pack fitted I'm also starting to try and work out loom routing . need to tap out a snapped exhaust header bolt but I'm on with that tomorrow .
  14. Gravel trap
  15. Gravel trap
  16. Gravel trap
    right calipers are a right state . after a night in soak I still could not turn the pistons so into the jizer and I've got a load of crud off . Ill use the compressor to fire them out and decide if I can polish them up or not . I then got onto the throttle bodies. looked like they had been sat in a lake but I reckon serviceable now at least .
  17. Gravel trap
  18. Gravel trap
  19. Gravel trap
  20. Gravel trap
    ordered a fuel tap too so once I've sorted loom positioning and thrown together we may get near fire up time.
