quick action throttle
Discussion in 'Mods, Upgrades, Accessories and Products' started by Yorkshire Tyke, Nov 17, 2013.
  1. kev.b
    kev.b Well-Known Member
    I have a quick action throttle fitted to my 06 Blade . Active quick Action throttle . Brought it from Calsport , works very well on the road . Comes with 3 diffrent throttle tubes and new throttle cables. I never liked the standard throttle . Its a great mod ! Works ok in traffic .
    #21 kev.b, Nov 17, 2013
  2. arthurbikemad
    Removed (item sold)
    #22 arthurbikemad, Nov 17, 2013
  3. Jamiestrada
    I will have it from you Arthur if that's ok
  4. Si.
    :D
  5. arthurbikemad
    lol, ok mate it's yours :)
  6. martinowen
    I'm not going to rush into modding the blade this time as I have wasted so much money on modding.................Jamie you have modded more in 4 weeks than I have in 4 years lol
  7. Jamiestrada
    Just know what I like on the blade from experience ;)
  8. Nutty Tart
    Nutty Tart Well-Known Member
    Yup +1 on the Active , that's what's on my scoot
  9. johnd
    johnd Active Member
    Are the active ones better than the hrc kit I've been looking at?
  10. Nutty Tart
    I can't answer that I'm afraid , got mine in a Calsport sale for £60 delivered
    Well chuffed :p
  11. johnd
    johnd Active Member
    Got yourself a great deal there!!
  12. Swiss T
    Swiss T Active Member
    The standard Honda throttle tube is 1/4 turn, that's 90 deg & really long. You can buy the HRC throttle tube for around £25; it fits the existing housing & cables. You will need to take all the slack out at the throttle body end. This tube will give you 1/6 turn. This is just a comfort mod & changes nothing with regard performance. Your brain to throttle hand connection takes about 10 seconds to recalibrate. Job done.
  13. BlackDevil
    BlackDevil God Like
    Accossato Quick Action Throttle Kits
    Top quality billet quick action throttle kits from Accossato. As supplied to Ducati Corse & used by Ten Kate Junior Superstock Team.
    Eiweiss-raceparts
  14. johnd
    johnd Active Member
    Ah right, the one i've been looking at has cables and the housing too for about £88.
  15. Swiss T
    Yes, but you dont need them pal. I have fitted the tube only to mine & it works pefectly.
  16. johnd
    johnd Active Member
    Nice one thanx mate, does the tube fit ok in the housing then? No trimming of plastic from the inside? Sounds a nicer/cheaper option than getting the whole lot.
  17. arthurbikemad
    You can run just the tube, the housing for the OEM tube is wider to accommodate the wider OEM tube, however you can as you say fit the narrow HRC tube/cam to the wide OEM housing, the cable ends on the OEM cables are wider than the HRC cable ends you can't run the HRC housing with OEM cables unless you file the ends, the HRC cables are designed for the kit as without them there is little play in the system, I've fitted just the tubes before and have had to remove the top nuts as the bike over revs on full lock as no free play, others have been ok but best is 0mm free play, you should have around 2mm, also with clip-ons (renthal etc) the OEM cables and HRC tube they are too short and run the risk of revving on full lock over rev on full lock is an MOT failure and can be dangerous. Hope that helps :)
    #37 arthurbikemad, Nov 18, 2013
  18. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    So if standard is quarter turn 1/8th turn will be a decent difference? Which kit would that be?
  19. arthurbikemad
    You notice them all IMO, just depends what you prefer. I fit LOTs of HRC kits.
  20. sinewave
    So you'd recommend the HRC kit over the others then Art?
