quickshifter plus fitting,
Discussion in 'General 1000RR Discussion' started by keithg1748, May 21, 2017.
  1. tuktuk
    tuktuk Elite Member
    I used long nose pliers on the outer coil plugs, fiddly but manageable.
    My cables run under the heat shield but cable tied so that they weren't resting on the top of the engine.
  2. keithg1748
    keithg1748 Active Member
    cheers mate.
  3. keithg1748
    what do you think about the rubber bit on the fuel pipe that snapped?
  4. tuktuk
    tuktuk Elite Member
    I thought how on earth did he manage that :p
    As far as i could work out its a kind of stopper to help keep it from unclipping itself but i certainly wouldnt be worried if i lost mine as the connectors are hard to unclip without them in the way. Make sure it all clips back together nicely and you will be fine.
  5. keithg1748
    well I finally got it fitted ( never again ) , not tried it yet though so I hope its ok. lol
  6. tuktuk
    tuktuk Elite Member
    Its all worth it i promise :D
  7. keithg1748
    I think I have lost the settings that was on it when I fitted it , whats your settings plz ?
  8. tuktuk
    tuktuk Elite Member
    Im using translogic. Think my mate with the hm set his to 90. Standard is 60 iirc? I think thats what the hm lite version is set to.
    Few people on here with hm will be able to let you know.
  9. keithg1748
    ok cheers mate.
  10. keithg1748
    evening all , can anybody give me any settings for a plus ss ? I must have wiped them that was on it when fitting , dohhh. thanks.
  11. keithg1748
    ive just set it at sens 60 and kill 64 does that sound right ?
