R77 fitted....very jerky at low RPMs
Discussion in 'Mods, Upgrades, Accessories and Products' started by stevebetts, Sep 23, 2011.
  1. JD
    JD Active Member
    Have the R77 fitted to my 2011 Blade and mine is lumpy at low revs, so I'll be going for the PCV/Remap once I've had the first service.
    JD
  2. abv
    abv Active Member
    Just a thought. Are you chaps running the O2 Sensor eliminator or have you connected the O2 sensor to your new exhaust ?
    Has anyone tried both to compare ?
  3. JM1
    JM1 Active Member
    Cool man. I've run baffleless for many years, but only recently switched to the light side :)
  4. JM1
    JM1 Active Member
    Eliminator for me but never compared the two, not scientifically anyway
  5. dan.1moore1
    You really need the Eliminator installed with a power commander otherwise it cant control the low rev range
  6. stevebetts
    stevebetts Well-Known Member
    do you have PCV fitted?
    surely you would not fit the o2 eliminator without it?
  7. abv
    abv Active Member
    This is what I was wondering was maybe causing some people problems where some people seem ok.
    I'll be in the market for an R77 when the new bike arrives but reports of poor running at low revs are a bit off putting. There is a bad enough flat spot as standard.
  8. dan.1moore1
    I ran an eliminator with out a PCV as the first can i bought had no hole for the sensor and the FI light came on . Bike was fine but Dyno jet would not sell me the eliminator with out a power commander so i got the 08-11 eliminator from a guy on ebay that is based in greece .
    I still have it if anybody wants it ?
  9. JM1
    JM1 Active Member
    Yes, that's the ony reason to run an eliminator!
  10. dan.1moore1
    i did to get the FI light off when i did not have a power commander
  11. stevebetts
    Is this problem limited to the R77?
    How do people with say the LV GP Pro fare?
    Comments please!
  12. dan.1moore1
    My bike ran like crap with a Hotbodies GP Growler
  13. stevebetts
    Has anyone got a baffle for an R77 they want to sell?
    I might try it with one in. I bought my zorst second hand and it didnt come with a baffle.
  14. slowr1der
    slowr1der Active Member
    i dont want to sell mine but you are welcome to borrow it for a few weeks to try and see if it runs any better matey
  15. Nutty Tart
    Nutty Tart Well-Known Member
    Yup .. I have recently removed a Leo Vince GP to fit a full system .. but I can report that it ran as sweet as a nut while it was on . Thats with or without the baffle
  16. rocket
    rocket Active Member
    i got a eliminater sent with my r77 but hoping to fit os sensor if i can so when it arrives i,ll see how it go,s !
  17. dan.1moore1
    There is a boss for the oxygen sensor on the s bend , Try it both ways and let us know the difference
  18. rocket
    yes a lot of people said there is a fitment for it but tom from biohazard said there isnt it so sold me an elminater at same time. when i get it and fitted if i can fir the original sensor at it runs ok i,ll leave it at that. will only try eliminater if i get a rough runner.!
  19. dan.1moore1
    Actually mine is a bit lumpy down low even with a power commander . Im only running a provided map so it will probably get sorted when i map the bike over the winter . I will let you all know in the spring LoL
  20. stevebetts
    What did you do with the Leo?
