Rear footpegs removed
Discussion in 'General 1000RR Discussion' started by Jamiestrada, Jun 20, 2011.
  1. rooroorooster
    rooroorooster Active Member
    Took me an hour an i'm crap with spanners but thought i'd have a go. As JM1 says, split and remove one side of the subframe at a time, it was fairly easy I thought doing it that way
  2. Jamiestrada
    It is defo the quickest way to do it :)
  3. abv
    abv Active Member
    I did this on my non ABS no problem but the ABS has a load of gubbins under the tail piece so I haven't attempted it yet.
    Has anyone removed the pillion pegs from an ABS model ?
  4. Remal
    not me but tempted.
  5. Jamiestrada
    If you do fit the plates, then you can fit them back on for your luggage or pillion :)
  6. vic_ster51
    vic_ster51 Active Member
    Riders seat off
    rear seat/cowl off
    Rear fairing off
    undertray off
    lift up where the fuses are (bolt hiding underneath)
    remove little plastic fairing
    take out the 2 pop plastic rivet things
    undo rear subframe bolt at rear
    remove 1 side subframe bolts, then subframe will pull out and down abit so you can get a allen key in there
    pull back up bolts in do same for other side
    quite easy really, also when subframe side is down you can route wires.. pc5 wires etc inbetween the undertray and subframe there is like a little duct.. very handy
  7. Remal
    Ok I want to give this a try but the pics on the thread are no longer here
    Was thinking pics from members would be handy for anyone looking at doing this
    Does anyone have pics to share
  8. Normanstanley
    Normanstanley Active Member
    footpeg photos
    look in my albums there is a load of pics how to take them off:)
