don t gonna work on 2004-2007 nd 2012-2015 (well sure can be mod , and bit for maps code changed ...but is not for all)
All the CBR600RR and CBR1000RR (except the first Generation PCV) Will plug into any of the models OK. They all use the exact same plugs. The issue is the fuel maps. The injectors voltages are different and the PC's work by altering the voltage applied to the injectors thus altering the amount of fuel they allow into the engine. So. While they will plug in using a CBR600RR PC3 from an 03 bike will plug into the 15 CBR1000RR you will need a custom map at least and then be dependent on the PC being able to achieve the voltage spectrum demanded by the 15 Blades injectors. Also the TPS will need to be properly calibrated as well and their are minor differences in TPS calibration and output voltages.
An 08 (Blade 132-411(410) PC3) will fit and work perfectly well on a 15 Blade. You will probably need a custom map as the fuel maps for the 08/09 bikes are significantly different to the 2014/15 fuel maps. I do wish people would stop making things up as they go along.
Btw diff. between wiring on PC 2004 -2005 injectors and tps connector 2008-2001 just injectors 2012-2015 injectors , tps and o2 sensor
BTW thats bollox....... Dont listen to this guy he is talking rubbish lol. Seriously he is. The injector plugs are the same on the 112,125-410 (411) PC3 USB (04-07 blade) unit as they are for the 132 PC3 for the 08 blade. The first generation PCV for yje 08-11 blade has different plugs but the earlier PC3 cabn be fitted with a custom map as can the later PCV which again returned to the same plug array as the earlier PC3 USB. The TPS plug is identical on all 1000cc blades. End of story. Dont be listening to the German. He is still pissed about loosing the war(s) lol
Never wrote connectors are different , what changed is on main wiring harness of those bikes(but U are not a dynojet point so for sure this info never reach your garage ) Also clear ,the good try ,to move the discussion to other points Sorry do not work .... I m not german just working for honda in germany end of the story
Feck that's pissed on my parade. Not quite sure now what his point was and he was very busy telling us everything was different. Now he says actually it's the same. Mmmmmmm maybe he us Japanese. They lost as well from memory.
