Just let me know via pm what you want just to update my cutter broke over the weekend just waiting for a new part then i can get the orders done sorry for the delay people
I have had a look on the net with no joy, dont want to start making them until there are right someone must have them on there big that could messure them for me please
Are you still looking for measurements? I can measure the ones on my bike or I might even have some spares to check. Will have a look when I get home this evening.
Not sure if you still want the measurements, but it turns out I have a spare set (complete with codes on them so I know they are genuine) The only problem with measuring is that some are slanted to the right. I figure if i measure across diagonally then it should be somewhere near. Showa L=80mm H=17mm (decal code 83732-MFL-G20 #1) Snap-on L=81mm =14mm on the "S" 13mm on th "p" (deval code 83727-MFL-G20#1) Brembo L=80mm H=18mm on the symbol, lettering is 15mm (decal code 83728-MFL-G20#1) Mivv L=83mm H=25mm (decal code 83731-MFL-G20#1) All measurements taken to the edge of the actual decal, if you want the actual lettering height best to get in touch and i'll do more measuring. Hope this helps
