RR7 track bike build
Discussion in 'General 1000RR Discussion' started by TomLum, Jun 28, 2021.
  1. TomLum
    TomLum Active Member
    Exactly this. Stock one is not visible to me when all hell is breaking loose on the track, the Healtech one has a lot of adjustability and very bright. Idea is to be able to see it in my peripheral without needing to take my eyes off the track.
  2. dern
    dern Well-Known Member
    It does have three levels of brightness but I didn't find it grabbed the attention enough.
  3. TomLum
    Update
    Had a small amount of oil weeping from engine covers around the rubber grommets for crank sensor and stator. Removed the cases to re-gasket
    Stator rubber was knackered so replaced with new stator.
    Cases were a little worn so decided to have them Cerekoted as a bit of experiment. They turned out well.
    Before
    After
    Some light pitting but to be expected given the age.
    Re-fitted, now just waiting for gasket to go off and will test for good seal
    • Like Like x 10
  4. TomLum
    New chain and front sprocket today in prep for first euro Trackday of the year Almeria in April. First time changing a chain, was pretty simple, glad I invested in a half decent chain tool vs cheap Chinese which I don't think would have been up to the job. Stuck with stock length 114 link which is at its max as ive gone +2 on the rear sprocket.
    Chain: DID 530 x 114 ZVM SUPER HEAVY DUTY GOLD X-Ring
    Sprocket: JTF333 Rubber Cushioned 16T
  5. Welly_59
    Welly_59 New Member
    Just reading this thread from the beginning .
    Where did you get the decals from? Looks lovely.
    Awesome bike
  6. TomLum
    Thanks! Ordered from https://moto-sticker.com Would highly recommend.
  7. Welly_59
    Welly_59 New Member
    I'll take a look! Did you spray with gun?
  8. TomLum
    Yes, paint is an Audi nardo grey, sprayed with air compressor and gun.
  9. warren smart
    warren smart Active Member
    I used stickers from this company for my Zx9r build and they’re good quality.
  10. TomLum
    After fitting the new sprocket and chain I wasn't happy with the lack of chain adjustment. Stock chain length (114) with +2 (44t) rear put the chain adjustment at its limit. I was already having to fight with the bike to keep the front end down under hard acceleration on the old chain and figured with the now even shorter wheel base this would have made things worse.
    Bought some additional links from Dennis Trollope race spares to extend the chain.
    Stock chain length with +2 rear sprocket
    After adding 2 links (116)
  11. TomLum
    Finally got onto a European track day and just come back from 4 days on Almeria. Absolutely fantastic time and while I struggled to keep up with the some of the newer bikes I did set a 1:53 which I was really pleased with. Hopefully get back there again later this year.It was organised through Focused Events who I would highly recommend.
    Bike performed really well but did blow a fork seal so will need to get that patched up. Next on my shopping list is a slipper clutch and some upgraded suspension..
  12. Muffking
    Looks fast from where I'm sat.
