Service due??
Discussion in 'General 1000RR Discussion' started by blade1980, Apr 17, 2012.
  1. MrB
    MrB God Like
    If your going on time it's oil and filter, if 4000 miles then check over only
    Hours labour, oil/filter/sump plug washer I'd price that at £90
  2. Dave V
    Dave V Elite Member
    Am I being thick? I thought the intervals x amount of miles or every 12 months?
  3. abv
    abv Active Member
    Me too. We're wrong
  4. abv
    abv Active Member
  5. abv
    abv Active Member
    But looking at this oil & filter changes are actually only every 12 mths. The 4K mile service is just inspect Brake fluid and Pads and Clutch System
  6. Dave V
    Dave V Elite Member
    Again being thick. isn't the point if the bike needs a service for warranty or not? When was the the 700 mile service done?
  7. Bikeracer1098
    Bikeracer1098 Active Member
    I've been told by my dealer that the bike requires a service including oil+filter change every 12months or 4,000miles whichever is first.
    I assume that you've had your 500mile service done when the bike was a few months old and then the 12 month service when the bike was 12 months old and had done 700miles. If this is so, the bike should have its next service when it is 2 years old (24 months).
    However if the last service at 700miles was done 12 months ago, then yes the bike does now require a service.
    Hope this helps!!!
  8. blade1980
    blade1980 Active Member
    Yes the last service was a year ago which was its 1st service at 700 miles. Having only covered a further 1000 miles since is it really worth it. Mainly just to keep its warranty if which there's only 4months left, and how much they want to charge me?
  9. gary1966
    gary1966 Active Member
    How i read it, 1st service is when you have run it in, 2nd service is 4000 miles or 12 months from when it was registered making it yearly if you havent hit 4k miles.
  10. blade1980
    Well Grantham Honda just quoted me £155! Oil and filter change, brakes stripped and cleaned, and check over and adjustments,
  11. Remal
    been quoted £270 for the first service at Fowlers in Bristol
  12. Jamiestrada
    Just rang Bransons and booked my bike in £145 for 1 yr service.......... Fowlers having a laugh !!!!!!!!!!!!!!!!
  13. Bikeracer1098
    Did you not get the 1st service done after 500miles after running the bike in?
    You should have then had the 2nd service done when the bike was 12 months old and then the 3rd service done when the bike is years old.
  14. Bikeracer1098
    That is a mistake, should be around £125 - £150 and Fowlers are usually the cheapest!!
  15. Bikeracer1098
    Your spot on.
  16. MrB
    MrB God Like
    Blimey, think I might have to put our prices up :eek:
  17. Jamiestrada
    Think I might have to ride down to cornwall ??? :)
  18. blade1980
    First service done 3 may 2011 at 600 miles, one year on from that hence now, service is due according to Honda which would be 12 months, my 1st service was £99 at Grantham Honda
  19. Bikeracer1098
    Honda recommendation for the 2nd service is 12 months from new rather than 12 months after the 1st/run in service.
    However if it was done on the 3rd May 2011, I would recommend that you get the 2nd/4000mile service prior to the 3rd May 2012 in order to preserve the remainder of the Honda warranty and also the residual value of the bike.
    Then get it done annually at the end of April/start of May.
    Even with the bike is not being used/not doing any miles the oil should be changes every 12 months to prevent internal engine moisture from contaminating the oil and damaging your engine internals!!!
    #39 Bikeracer1098, Apr 18, 2012
  20. blade1980
    That's what I'm going to do, I'd prefer a full Honda history and should anything happen at least the warranty will be covered
