Small crack on the front fairing (windsreen screwhole) fix?
Discussion in 'Maintenance' started by bazz, Nov 10, 2012.
  1. bazz
    bazz New Member
    Thanx Phantom. I used that gel glue yesterday, also took glued in a thinn plastic peice to support the area around the crack. Not visable and i hope the crack will stay the way it is now.. hardly not visable.
    If it get worse ill check with Cox Honda or MrB here if they can help out with a good price on the cowl. Or ebay =)
    Hugh thanx guys.
    Got to say that im really starting to love this forum.. so much helpful people around here :)
    Regards Bass
  2. maxvis
    maxvis New Member
    If I can give my 2 cents...usual superglues like cyanoacrylates are very rigid once dry, thus they don't absorb any vibrations once cured (so that the crack can run again even if repaired with cyanoacrilates); the best thing to "repair" cracks on a fairing is to use some epoxy double component superglues and two shimmers.
    If the crack has started from a bolt hole in the fairing, best thing is to find 2 little plastic/rubber shimmers the size of the bolt head (they also have to be very thin merely for aestethical purposes) then apply some epoxyglue on the inside of the shimmers and glue them just around the cracked hole. Then tighten with the bolt and nut before the glue dries. (this kinda shimmers are often used on fairing fasteners so that the fastener don't scratch the paint on the fairing, ducati's and mv's have them on their quick detach fateners).
    hope this helps.
    Massimo (sorry for poor english)
  3. kpone
    Better English than mine Max.
  4. phantom
    phantom Active Member
    that gel glue allows flex ;)
    mine has been glued and still holding since july
    and I didnt crack mine, I snapped the fairing clean
    off just below the mirror.
  5. levin
    levin Active Member
    Sorry maxvis, didnt mean to like ur post , when scrolling thru pages on tapatalk it does that , 2nd time its happened to me anyway..
