Get yer sen down there Matt! This is the Track where Mr Rutter raped every other Sportsbike going on a pretty much standard ZX10R using the same rear Ohlins shock as you have. http://1000rr.co.uk/trackdays/21935.htm Gives ya sumat to aim for!
Not really done much the last few days. Brought it into work the other day to make full use of the air lines! (I hate working in my garage, no room) The shock is all tight now and mainly just spent today cleaning and tidying up the wiring at the front. Don't look too bad does it. Still to do:- rear sets Chain+sprockets Fit the airbox and fuel tank Fit the exhaust Get my numbers Oil+filter Lock wiring Wire in the rain light Drill swingarm for chain guard
Don't forget to do a Full Coolant flush and refill with Water James as you can't use Coolant if racing!
