sp 2014 price confirned
Discussion in 'General 1000RR Discussion' started by graemewalker, Nov 23, 2013.
  1. CastrolCraig
    CastrolCraig Active Member
    Its very different.
    Top end is redesigned, lighter, whole engine is blueprinted & matched at the factory, wheels are different, ratios are different, frame has a brace in headstock area that the standard bike doesn't either.
    As has already been said, it serves two purposed, it gives the Honda SSTK teams a valid weapon to use and it also shifts units in the sales figures.
  2. BlackDevil
    BlackDevil God Like
    Here are all the answers ( Part I ):
    The chassis wears circuit-ready front and rear Öhlins suspension plus Brembo four-piston mono block calipers, with frame revisions and new top and bottom yokes to suit. Honda’s electronic Combined Anti-lock Brake System is an option, with software remapped appropriately. Pirelli Diablo Supercorsa SP tyres are the finishing touch.
    The 999.8cc inline four-cylinder engine gets the same updated cylinder head as the standard 2014 CBR1000RR Fireblade, with improved inlet/exhaust gas flow and combustion efficiency, and the extra 2kW peak power boost. However it features factory-matched pistons and con-rods, to ensure optimum internal balance.
    Single seat unit and unique Tricolour paint – white and two-tone blue, with a central red stripe and trademark Honda gold wheels.
    The CBR1000RR SP’s die-cast aluminium twin-spar frame is based on that of the standard machine, with modifications to match the Öhlins suspension. Tuning the frame to increase rider feedback with the suspension’s different performance parameters proved critical during development and the rigidity balance around the rear suspension mount has been revised to give more flex – and therefore feel – for traction.
    The Öhlins inverted front fork has an outer diameter tube of 55mm (1mm more than the Showa unit) and the revised top and bottom yoke use a steel, rather than aluminium, steering stem. The top yoke itself features high precision CNC machining and features a greater surface area in contact with the forks, improving rigidity.
    As on the CBR1000RR the aluminium gull-wing swingarm operates through MotoGP-derived Unit Pro-Link rear suspension. Rake is set at 23° 30’ with trail of 96mm and wheelbase of 1410mm. Kerb weight is 199kg with front/rear weight distribution of 52.7%/47.3%
    The second-generation Honda Electronic Steering Damper (HESD).
    Compared to the 2013 year model CBR1000RR, the footpegs are set 10mm back and the handlebars are wider, lower (by 1°) and further forward (by 5°). A new rear subframe – with no need to support a pillion – is lighter and the revised seat material firmer. A new screen delivers improved high-speed aerodynamics rather than wind protection.
    Specialists from Öhlins worked with Honda’s engineers and test riders during all stages of development. Fully adjustable, the 43mm inverted fork and rear shock were developed specifically for the CBR1000RR SP, to offer superbly balanced all-round performance and greater potential for cutting lap times on a closed circuit.
    The 12-spoke cast aluminium wheels perfectly complement the new suspension setup. The front 17in x 3.50in rim wears super-sticky, track-ready – and fully road legal – Pirelli Diablo Supercorsa SP tyres; a 120/70-ZR17 front and a 190/50ZR17 rear on a 17in x 6in rim.
    Brembo mono block four-piston calipers were chosen because of their compatibility and performance potential with the Öhlins fork. The caliper body is standard but Brembo manufactured special pistons for use in the new machine, with pad material designed to give consistent and linear feel when braking hard from high speed.
    Honda’s electronic Combined ABS is an option on the CBR1000RR SP. The system has been used in every race since 2010 in the IDM German national championship by the Holzhauer Racing team, whose rider Karl Muggeridge won the series in 2011. It has also been used by the Honda TT Legends team in the Endurance World Championship series since 2011.
    For the CBR1000RR SP, know-how gained in racing has been reflected in refinements to the system. Compared to the standard machine, activation of the rear brake distributes less braking force to the front. The adjustability of the electronic system has also been used to make initial activation of the ABS system even more gradual and smooth.
    The combined element of the system varies the distribution characteristics of braking force as the front or rear brakes are applied and released. The system is set up so that when the rear brake is applied gently, the front brake is not activated. This allows the rider to use only the rear brake for small adjustments to speed, useful in Super Sports riding such as when settling the bike for corner entry. In this area too, feedback from racing activities has led to a new programme for the CBS activation. As the rider releases the front brake, the rear brake is released more quickly to allow lean angle to be maintained more easily through the corner.
    The CBR1000RR SP’s 999.8cc, 16-valve inline four-cylinder engine has the same cylinder head updates as the standard machine. The inlet and exhaust ports have been re-shaped and polished with the combustion chambers ‘gas-flowed’ to improve efficiency.
    Gas-flowing (flow-testing through an air-flow bench) effectively improves both the quality and quantity of airflow at high rpm when air resistance becomes much greater; increased combustion efficiency and outright power results. The valve seats have also been revised to match the cylinder head work and the intake funnels are now ‘slash cut’, a design used in WSB.
    Where the SP differs is the selection of ‘middle value’ pistons as the engine is manufactured. Essentially a factory blueprint, each batch of pistons and rods are weighed and those that most closely match the middle tolerance – and each other – are used. This injects an even greater level of balance into the engine, especially at the high rpm generated on track.
    Bore and stroke is set at 76mm x 55.1mm with compression ratio of 12.3:1. A nickel-silicon carbide (Ni-SiC) surface treatment on the cylinder walls reduces friction and ensures reliability. At 35mm (from 38mm) the exhaust pipe diameters are smaller, increasing torque and a new vertical connecting pipe balances pressure between cylinders two and three. Peak power of 133kW – up 2kW – arrives at 12,250rpm; torque is improved in the 4-6,000rpm area, peaking with 114Nm delivered at 10,500rpm.
    The Programmed Dual Sequential Fuel Injection system (PGM-DSFI) has been remapped to match the revised cylinder head and exhaust. It delivers precise fuelling and an accessible power delivery, perfect for driving hard out of slow-speed corners. At throttle openings of up to 25% the PGM-DSFI delivers relatively fine and consistent changes in power and torque output – perfect for extracting maximum drive at full lean. As throttle openings become larger, the changes in output are progressively greater and the overall result (at the throttle) is an engine that responds with great accuracy to rider input, giving superb feel from the rear tyre and highly usable, linear acceleration.
    The MotoGP-derived slipper clutch ensures full power transmission together with ultra-smooth gear shifting and light feel at the lever. In the critical hard braking, back-shifting corner-entry phase it decreases the torque passed from engine to the rear wheel, reducing the chance of traction loss and increasing stability.
    Combined with the chassis changes ‘Total Control’ is elevated to a whole new level and the CBR1000RR SP has the potential to turn in significantly lower lap times than the standard machine.
  3. BlackDevil
    BlackDevil God Like
    Part II.
    The CBR1000RR SP uses a new ‘wave’ design ignition key. Also new is the fuel tank cap – it uses an improved breather design for better venting.
    Instrumentation is a multi-function LCD with a cockpit display dominated by the digital bar-type linear tachometer that scrolls left to right as engine speed increases.
    Beneath this are the main numerical readouts: gear position, coolant temperature, speedometer, clock/lap time, trip/fuel efficiency/fuel consumption and odometer/numerical tachometer. At the bottom of the display are lights for headlight high beam, neutral and indicators.
    Clear and easy to read in all light conditions, the tachometer has four display modes: Conventional, which uses black LCD segments to show current rpm; Reverse, which employs black LCD segments to show remaining rpm. Peak Hold indicates rpm in the conventional way and also leaves a tell tale segment showing the peak rpm achieved while Single Segment uses a single block to show current engine speed. In addition the odometer may be switched to display engine rpm numerically.
    The lap timer features four modes. The display can also show fuel consumption, average fuel efficiency, distance travelled and total elapsed time. To assist debriefing after a session, lap time recall mode shows the fastest lap time and the lap on which it was set.
    To ensure gear shifting at the optimum engine rpm, the 5-level shift indicator display uses highly visible white LEDs, adjustable for brightness. They illuminate sequentially as engine rpm rises, finally blinking at a chosen pre-set rpm (default is 13,000rpm but this can be set between 4,000rpm and 13,000rpm). The interval between sequential illumination can also be set at 0, 200 or 400rpm.
    The CBR1000RR SP can be personalised with a range of Honda Genuine Accessories.
    A painted hugger.
    A carbon-fibre hugger is based on that used on the Repsol Honda RC213V in MotoGP and features a Honda Racing logo.
    Similarly, at the front end, a carbon-fibre mudguard.
    A set of quality carbon-fibre crankcase covers protect the powerplant with an advanced composite cover on the left and, on the right, also protecting the clutch cover, a guard featuring the Honda Racing logo.
    High windscreen - A black-tinted high windscreen – 27mm higher than standard – gives added wind protection, while complying fully with European homologation regulations. It also integrates perfectly and, even with its side stays, does not compromise visibility, drivability or manoeuvrability. To underline the CBR1000RR’s racing heritage, a Honda Racing logo is featured on the high screen.
    Other CBR1000RR accessories:
    • Averto alarm
    • A series of tank pad and fuel filler cover sets
    • A comfort seat E-cushion
    • A rear maintenance stand
    • 2 indoor cycle covers and an outdoor cover
    • A tank bag
    • A wheel sticker set
    • A Honda OptiMate 5 battery optimiser
    • A fairing scuff guard set
    -- Model: CBR1000RR SP
    • Engine Type: Type Liquid-cooled 4-stroke 16-valve DOHC inline-4
    • Displacement 999.8cm3
    • Bore x Stroke 76 x 55.1mm
    • Compression Ratio 12.3:1
    • Max. Power Output 133kW (178hp) @ 12,250rpm
    • Max. Torque 114Nm @ 10,500rpm
    • Oil Capacity 3.7L
    • Induction - PGM-DSFI electronic fuel injection
    • Fuel Tank Capacity 17.5L
    • Fuel Consumption 18.0km/l ( WMTC mode*)
    • Clutch Type Wet, multiplate with diaphragm spring
    • Transmission Type 6-speed
    • Frame - Type Diamond; aluminium composite twin-spar
    • Dimensions (LxWxH) 2,080 x 720 x 1,141mm
    • Wheelbase 1410mm
    • Caster Angle 23° 30'
    • Trail 96mm
    • Seat Height 820mm
    • Ground Clearance 130mm
    • Kerb Weight 199kg (ABS: 210kg)
    • Front Suspension - Type Front Telescopic inverted fork with an inner tube diameter of 43mm, and a NIX30 (OHLINS) Front Fork with preload, compression and rebound adjustment, 120mm stroke
    • Rear Suspension - Type Rear Unit Pro-Link with gas-charged TTX36 (OHLINS) damper featuring 8mm preload and 22 click compression and 22click rebound damping adjustment. 60mm stroke.
    • Rims - 12-spoke cast aluminium - Front 17M/C x MT3.5 - Rim Size Rear 17M/C x MT6
    • Tyres - Front 120/70 -ZR17M/C (W) - Rear 190/50 -ZR17M/C (W)
    • ABS System Type Electronic Combined ABS
    • Brakes - Type Front 320 x 4.5mm dual hydraulic disc with 4-piston Brembo Monobloc calipers and sintered metal pads
    • Brakes Rear - 220 x 5mm hydraulic disc with single-piston caliper and sintered metal pads
    • Instruments - Gear position, coolant temperature, speedometer, clock/lap time, trip/fuel efficiency
  4. lambchops
    lambchops Elite Member
    Quite a few tweaks then.. standard wheels though :)
  5. navvy10
    navvy10 Well-Known Member
    I specifically asked about the wheels and the Honda guy at stand who is flying out to test the bike with the top boys said the wheels are lighter than the current 2012/13 wheels..... :rolleyes:
  6. Dave V
    Dave V Elite Member
    I heard him Nav, he certainly did.
  7. lambchops
    Sales people eh... They don't know there arse from their elbow :)
  8. MrB
    MrB God Like
    Weve sold 2
  9. Dave V
    Dave V Elite Member
    Are the wheels different mate?
  10. MrB
    MrB God Like
    Finding out
  11. MrB
    MrB God Like
    Well I've had a look through all the official information and can't find any mention of lighter wheels etc.
    If they were Honda would be banging on about it I'm sure and bullet point the fact in all the press releases.
  12. wedgiewolves#223
    wedgiewolves#223 God Like
    I asked and NEC he said wasn't sure "i don't think so " lol (wheels)
  13. lambchops
    The only diffrence is they are a coool gold colour :) Still think 15,500 is a bit steep, resale value should be very good though if they are sold in limited numbers so bonus there! Still think I would get a Panigale over the blade if I had 15k to blow.
  14. graemewalker
    graemewalker Elite Member
    agreewith lambchops the sales peole at the nec were as much use as a choc fireguard and i agree with lambchops the wheels are the same as 2013 and they surely would have mentioned it otherwise.any way when i get it i will weigh the rear and compare with 2013 and let u all know but to be honest i dont think there will be any diff
  15. Jamiestrada
    Changing the tyres on my bike over the weekend so will weigh the rims without tyres if it will help ... But they are Repsol wheels so will probably be lighter than ordinary blade wheels anyway lol
  16. lambchops
    Do you have an delivery ETA yet Graeme?
  17. Beckers
    Beckers Elite Member
    You didnt speak to me then buddy...........and what is a peole anyway?
  18. Beckers
    Correct! :D
  19. Beckers
    Yup some for racing
  20. graemewalker
    craig at newcasle said february i told him i only want non abs but he spoke to honda on monday and he will be getting two one of each i am leaving it standard apart from hm q/s which will be installed.i will post pics of it in february at the shop but i am not going to reg it until april?u say why i cant tell u until tomorrow but i will give u the reason then and u will agree that i was right not to say,i bet u are all wondering what the f--k is he on about but will be all revealed tomorrow:)
