SP Subframe part number
Discussion in 'Mods, Upgrades, Accessories and Products' started by si1000repsol, May 13, 2014.
  1. PeterT
    PeterT Active Member
    Is that with or without the rear pegs I wonder?
  2. si1000repsol
    I hope not but judging by the trellis effect they have made its quite a lot of metal cut away i am leaning towards it being true
  3. PeterT
    I hope so, then I can get my dremmel out to start removing some HEAVY METAL.:eek:
  4. si1000repsol
    It has unthreaded points that were for rear pegs. These could be drilled out for more weight saving ;-)
  5. RedMacGregor
    RedMacGregor Active Member
    What's with this weight saving thing? If you are the size of Dani Pedrossa I get it but most of us could shed a stone or so. It's a cheaper option than a light weight subrame and you will feel better for it.
  6. si1000repsol
    Yes very true but why not lose some body weight and also reduce the weight of your bike too?
  7. RedMacGregor
    There must be a point of diminishing returns with this weight saving that is cost V weight saving. I think we all need to be honest and admit there is more than enough power in a stock weight Fireblade. What it really is an excuse to spend vast amounts of money on shinny bits and pieces. I already only weigh the same as Dani P so I think I am allowed to buy lightweight parts but I've seen a few pie eaters on sportsbikes where you would need some serious lightweight parts to offset the pies.
    What we need the Honda Fireblade Carlsberg Edition - with everything you could ever want fitted as standard.
  8. JWRusk
    JWRusk Active Member
    will be buying this subframe as well to fit my bike
  9. si1000repsol
    Remember to share some pics when its done.
  10. JWRusk
    Indeed I will
  11. Stevie_d
    Stevie_d Senior Member
    How much difference is 1kg in weight gunna have ? How much are those sub frames btw ?
  12. si1000repsol
    TBH not a great deal unless you are looking to reduce weight on the whole of the bike. They do look awesome and thats another selling point.
    They are around £400 from dealers.
  13. Stevie_d
    £400 ain't too bad then really
  14. JWRusk
    Is there a difference in the ABS , and non ABS SP subframe?
