I had a 12 Anniversary model. Weighed about 12 stone kitted out and ran standard settings, perfect for the road.
14st, new Blade, I tweaked mine based on my Alpha set up on my 08 as a base and then tweaked slightly on the road, feels much better, not perfect yet but 90% better Rear Spring +1 to 5 Rebound 1 turn softer R compression 1/2 softer, next ride out will try putting this back to standard Frt Preload +2 turns harder, may go another turn harder Rebound 1/2 softer Compression standard It's not a lot but takes the harshness out of it
its £50 now but he only does a couple of days a month and its on a first come basis im hopefully going next month.
Do they let you take it for a spin and go back to make adjustments or is it more setting the basics and off you go ? Cheers
http://www.1000rr.co.uk/threads/just-got-suspension-set-up-done.20354/ couldn't find original document, but here is the link to the post on here ! @tony lomas Steve
Just had a set of 2014 forks serviced and sprung to my weight by Darren at MCT, Stowmarket for my rr9. Went for a short ride yesterday and felt so much better than my old 2009 forks, soaked up bumps that before would of cringed at hitting and turned better too. Wish I had the time to get him to set them and the Ohlins TTX also up.
Yes. Gareth will send you off for a spin and fine tune if needed. Really can't recommend the bloke enough
