Temperature.and tick over speed.
Discussion in 'Maintenance' started by mal, Dec 24, 2011.
  1. CastrolCraig
    CastrolCraig Active Member
    Rpm not temp lol
  2. megawatt
    megawatt Well-Known Member
    My rrw normally runs at 80c, fan cuts in at 105. Takes about 15/20 mins on tickover to reach 105. That ain't reading Fahrenheit. Check it with a thermometer and give rad a clean?
  3. dave d
    dave d Elite Member
    yeah 85c is 185 f!!
  4. Nutty Tart
    Nutty Tart Well-Known Member
    Thats the sort of temps that megawatt deals with at work :)
  5. mal
    mal Active Member
    hello all,i was out on the bike yesterday wed 28th went down M and P, All A & B roads, then back home to cardiff via Llandovery, and the vanda, A470, my max temp, was 78,...is that good,bad right wrong ?.............mal
  6. Remal
    Mal, at this time of the year that would be fine. as it's cold mine is about 80 when it's also cold
  7. megawatt
    Sounds spot on Mal. As long as you are moving the temp should stay around the 80 mark and pick up when you are stationary!
