The lights are on but no one's at home...
Discussion in 'General 1000RR Discussion' started by mikesouthby, May 17, 2014.
  1. racman
    racman Active Member
    Battery fekked. They fail almost instantaneously now days
  2. Mike07
    Mike07 Active Member
    Doesn't completely rule out the battery but its starting to point in other directions; Reg/Rec, Stator. Before my money left my hand I would get a test done. Google tests, plenty of advice there.
    I would test the Stator output Volts about 50v at 4/5000 RPM.
    Mike.
  3. Mike07
    Did you get it sorted?
    .........Mike.
  4. mikesouthby
    mikesouthby Active Member
    Yes, fitted a new battery and all has been well since :)
  5. Mike07
    Great news,
    .....Mike
  6. RepsolPaul
    RepsolPaul Well-Known Member
    I've bumped mine when the old battery was on its way out, once was outside Zipsters house leaving the lights on as we chatted.
    Bought a SPS lithium Ion and that did go down once also leaving the lights on !!
    Got to return the battery to see if it's a bad one they said, will have to do it after my Mugello trip now.
