Thinking about buying a track bike
Discussion in 'Trackdays' started by ColinBR, Aug 6, 2014.
  1. ColinBR
    Ah ok. Is that something that's only in the first few gears that most Gixxers have?
  2. ShinySideUp
    ShinySideUp Elite Member
    Under the tank.......engine ecu is under the rider seat does it connect to a three wire white plug? Think the wire colours are pink/blue/poss grey wires in connector?
    It sounds like a TRE (timing retard eliminator!) it tricks the ECU into thinking the bike is always in 6th gear in order to bypass the electronic timing retardation that's built into the fuel maps in ECU for first 4 gears.
    Does not alter rev range the bikes capable of...but in some models it can remove the top speed restrictions on the likes of the busa.
  3. Alblade
    Alblade God Like
    This is it, think it's French
  4. ColinBR
    Looks like the TRE Craig is on about.
  5. ShinySideUp
    Yup that's the TRE unit I was on about, it basically tricks the bike into thinking your in a higher gear than you are and stops the ECU from using modified fuelling maps that retard the ignition and add more engine braking while in the first 4 gears, speed derestriction is not used on 600/750 bikes.
    It is really just a couple of quids worth of electrical components in a plastic box an a sticker flung on it and charged 100 quid for it! The build diagrams are widely in circulation on the web but the main difference is some are gear indicator friendly so still allow the correct gear to be shown on the dash or gear indicator unit rather than what the ECU is being tricked into thinking the bike is in ie sixth gear.
    In its most basic form one 20p resistor can do the same job if the gear indicator showing wrong gear is not a concern to the rider!
  6. ColinBR
    Well finally got round to buying a track bike today.
    Bike is in need of a lil bit of TLC, but nothing that we are not prepared or used to doing.
    I may even start a new thread on the making of this bike.
    #66 ColinBR, Aug 31, 2014
  7. Garyb
    Garyb Moderator.
    Nice one Colin, will she be ready for the 25th September?
  8. martinowen
    What did you get Colin?
  9. Mad Matt
    Do it Colin, will make for a good read...
  10. And7rp2
    And7rp2 Elite Member
    look forward to reading about this one ;) hope the idiot who looked over it for you didnt miss anything nasty :eek:
  11. ColinBR
    Nothing nasty to report. Stripped it rite down now and have tallied up all that is needed.
    Thanks again for checking the bike over for me prior to me picking it up mate.
  12. Daznorthwest
    Daznorthwest Elite Member
    What have you got col
  13. And7rp2
    thank Fook for that :D ........... hope you do a build thread.?
    Get down to the NEC n you can buy me a pint ;)
  14. reid7606
    reid7606 Active Member
    Must admit I've been toying with a track bike, and I had a few questions , does it make you a better rider, cost etc. but what is the best bike to choose, seen a 954 blade, Gsxr 750, or a 600 ninja?
  15. ColinBR
    Hi mate
    It will definitely make you a better rider, and give you more confidence.
    Price wise it'll come down to your budget. I set mine at £3k max and seen a few that were of interest.
    Personally I was looking for a GSXR 750 because of my size, or I would have had a 600.
    That's not to say you can't jump on a bigger bike though, because at the end of the day it's you right hand that controls the bike not the other way around.
    I was all for buying a forum members friends GSXR until another bike turned up.
    I think it may still be up for sale. It also is a GSXR 750
  16. reid7606
    Thanks for that
  17. Barstewardsquad
    A track bike won't make you a better rider. Riding on track and exploring the limits of a bike will make you a better rider. Having a bike on track that you aren't so concerned about crashing will help you push the limits even more.
