Track bike build
Discussion in 'General 1000RR Discussion' started by RepsolRuss, Nov 23, 2014.
  1. SimonT
    SimonT New Member
    Looking good and very inspiring.
    I'm just about to start on a similar project but have to admit to being a total noob. I'm so bad I even had to buy all the tools before I can start!!!
    Just a few questions if you have time.
    How/what did you use to bypass the side stand switch?
    Do you have to relocate the catch bottles - do the clash with the race fairings/subframe?
    Is it best to get a new nose subframe or does the existing work ok?
    Any other top tips?
  2. graemewalker
    graemewalker Elite Member
  3. RepsolRuss
    RepsolRuss Active Member
    Got back from working at the Le Mans 24hr yesterday for Prime Factors Racing to be greeted with these beauties. I'm over the moon with them. Practically brand new having covered only a couple of hundred miles. image.jpg image.jpg
    Will get them on the bike this week, along with fairings etc. My first outing on the bike is May 5th at Silverstone. Itching to get out
  4. Gilesy
    Gilesy Elite Member
    wow wow wow... very jealous! look amazing and Im sure will transform the front end...
  5. ShinySideUp
    ShinySideUp Elite Member
    Eh Russ, I hope there isn't a Le Mans bike in the back of a truck missing a set of forks...........:D
  6. graemewalker
    U lucky man first dibs if you sell please
  7. RepsolRuss
    Ha ha no mate. These are the poor man variety. Wouldn't mind a set of Superbike forks though lol
  8. graemewalker
    They are fine as far as I am concerned mint
  9. RepsolRuss
    Recived my fairings from Motocarbons. Absolutly over the moon with the quality & finish. Wasn't going to paint them and just run them in the white gel coat with decals. However, the tail piece was made in two sections and bonded together. Where the upper & lower parts met, there was a band approx 5mm wide that need prep & paint.
    So I decided to tape out the contour lines and paint in gloss black. Once painted I used a fluro wheel rim tape to outline the black. image.jpg image.jpg
    I'm happy with the finished product. I'll paint the belly pan to match along with the air intakes
    #89 RepsolRuss, Apr 26, 2015
  10. Moon
    Moon Active Member
    I like this a lot! Pics of the whole thing when finished please :)
    And can you come and do mine
  11. deano69
    deano69 New Member
    Looking sweat..when's the big reveal..
  12. RepsolRuss
    Thanks for the positve comments guys.
    Bike will be finished this weekend. I'll post some pics up then
  13. SimonT
    SimonT New Member
    Do you want to come and finish mine after...........:)
    • Old Old x 1
  14. RepsolRuss
    Yeah no probs
  15. SimonT
    SimonT New Member
    Challenge on to complete first though mine is looking a little less Gucci...
  16. RepsolRuss
    Bikes put together and finished. Just a couple of bits of fairing to paint to match the tail piece and I'd say it's Job done. Not going for anything fancy paint wise. Would rather spend my money on track time and tyres.
    In total it's taken 7 months to build. It started life as a rolling chassis & looking a bit sorry for its self. It's transormed quite a lot in that time.
    Spec list is
    2011 Honda CBR1000RR Fireblade
    Renthal clip-ons
    Renthal chain & sprockets
    Brembo RCS Master cylinder
    Brembo Seria Oro discs
    Brembo M4 mono block callipers
    Ohlins front forks with 30mm internals
    Ohlins TTX rear shock
    Full Titanium Arrow world superbike exhaust system (Ten Kate)
    HM Quick Shifter
    Gilles rearsets
    Motoholders HRC factory subframe
    Motocarbons HRC factory bodywork
    R&G engine, fork & swing arm protection
    Pro Fiber Carbon fiber frame covers/protectors
    HRC 1/6th Quick Action Throttle
    HRC overflow catch tanks
    HRC rear brake res.
    HEL braided brake lines
    K&N Airfilter
    2014 Spec CBR1000RR multi spoke wheels
    Can't wait to get out and give it a good kicking ;-)
    #96 RepsolRuss, May 7, 2015
  17. Muffking
    I can't hep with your other questions, but I had to refit the side stand parts on my bike as the previous owner went without the side stand. Basically you just follow the side stand switch back to the plug and short it out. In my case the previous owner had shorted the wires on the sidestand connecter itself, making it easy for me to disconnect the plug when refitting a new sidestand.
  18. RepsolRuss
    Sorry guys, I must of missed this.
    I removed my side stand along with the wires & plug. I cut the wires and plug from the side stand which just left the plug with approx 1.5inc of cable. I cut the wires back, soldered them together and heat shrinks them back together to make them water tight. Then refitted the plug back in to the connector just inside the frame.
    Perfect if you dont use a side stand.
  19. Gilesy
    Gilesy Elite Member
    She looks great.. just what Im after for a toy. I should have started something in the winter but only just got the bug now after my last track day 2 weeks ago.. hope you enjoy her, looks the business!
  20. KPH
    KPH Active Member
    That looks really nice - lots of good components.
    I saw that the exhaust is touching the fairing ( same as I've found on mine) - whats the best way to protect it the fairing from getting too hot - wrap the exhaust and but heat-reflective tap on the inside of the fairing ?
    PS. if you ever want to sell the forks ......
    • Friendly Friendly x 1
