Track Day Upgrades
Discussion in 'Mods, Upgrades, Accessories and Products' started by SimonT, Apr 3, 2015.
  1. Shane_L
    Shane_L Member
    Good luck getting that Austin through noise testing I've got that on my blade and it idles at 103-105 with both baffles in! But it does sound amazing! Good luck with the build it will look nuts when your finished with it.
    • Optimistic Optimistic x 1
  2. SimonT
    SimonT New Member
    Well I hope not - the main reason I went with the AR was their reassurances on the DB levels.....
  3. SimonT
    SimonT New Member
    Well had a bit of fun and games today. The Motoholders rear subframe came with a convenient battery holder, unfortunately the cables were not long enough to reach it!! There was also no where readily provided to attach all the rest of the gubbins that filled the rest of the old sub tray.
    They must be designed for race looms as it was a bugger getting everything to fit!!!
    So with a fair bit of faffing and half my supply of cable ties I managed to botch something together....
    Also managed to have a good go at the fairings, still have a couple of fasteners to drill through and need to make some sort of bracket for the belly pan but apart from that it is now starting to look like a bike again!!!!
  4. KPH
    KPH Active Member
    I had the same issues with the MotoHolder subframe. It's a bit annoying that they don't make it clear on the differences, or even sell brackets etc.
    For the battery issue, I bought a ballistic quick-release set, which gives a lot more length.
    I also had some brackets made for the fuse box and other parts.
    For the fairing brackets, I bought the set from TenKate that comes with the Dzuz 1/4 turn fasteners - they make fitting the fairings sooooo easy
  5. SimonT
    SimonT New Member
    Made a little bit of progress this week.
    To free up a bit of space in the rear subframe I binned the servo and fitted one of these little items.
    Then got to work on the rest of the fairings. Never had any before so not sure what the quality should be like but they seem ok. Had to make a little bracket out of ally to hold the belly pan.
    Hel lines fitted all round, thanks to bit of help from forum members as I forget to bleed the MC, and a set of SBS track pads up front.
    Just need to fit the new chain, waiting for the new rear shock to arrive as the K-tech one wouldn't fit and set up the suspension. I'm going to get it sound tested Wednesday at Castle Doom and if it passes there it will pass anywhere!!!
    Just going to leave the fairings unfinished for now and have a think about something over the winter. Its not a looker but hopefully a goer.....
  6. RepsolRuss
    RepsolRuss Active Member
    Nice looking fairings. Look good quality.
    I cut the loom back and re-wrapped for the battery and cables etc to fit the ally box provided. I'll take a pic and post it up when I get a sec :)
  7. SimonT
    SimonT New Member
    Also fitted R&G engine casings, cotton reels and fork sliders - anything else needed in the way of protection?
    I also weighed everything taken off and put back on and saved in the region of 17kg's or about 8% of the kerb weight!!!
    Also to anyone else thinking of doing the same, before this I had never even changed the oil on a bike and pretty much had to buy all the tools for the job. So if I can bodge something together anyone can. Thanks of course for all the help given on these forums.
    Cheers
    Simon
  8. Cbrjay
    Cbrjay Well-Known Member
    By any chance it catches the swing arm?
  9. SimonT
    SimonT New Member
    Yes it did....
    K-tech say they have sold over 200 for the 2008+ blade with no reported problems...doesn't make sense?
  10. Cbrjay
    They offered me the shock the other day
  11. SimonT
    SimonT New Member
    As suggested I have refitted the side stand - it needed the belly pan trimming and a new bracket made and fitted.
    Very minor I know, but removed all the Honda safety stickers from the side of the swing arm. Borrowed Mrs T's hair dryer - probably the first time GHD's have been used in a motorcycling context.
    Fitted the "special" baffle and some exhaust wadding reading for Castle Doom Wednesday.
    Finally some slave labour for a wash down.....
  12. Scott
    Scott Active Member
    My rear axel nut is on the other side. Does it make a difference ?
  13. RepsolRuss
    Well spotted. Mine too
  14. Barstewardsquad
    Think it should be on the right. That way the direction of rotation would tighten rather than loosen the nut.
  15. SimonT
    SimonT New Member
    It was on this side when I bought the bike - its only a 5 minute job to swap over if you think it needs doing.
  16. graemewalker
    graemewalker Elite Member
    image.jpg As bar steward says better on right that way when u tighten axle nut it takes up slack on chain other way it tends to knock it out,Harris do it that way for that particicular reason as stated
  17. SimonT
    SimonT New Member
    Swapped over....
  18. SimonT
    SimonT New Member
    The last of this years bling arrived, any more and Mrs T will string me up.....
    Also picked these up as the rear linkages were looking a bit ropey.
    Just need to get it on track now - roll on the 19th.....
  19. Gilesy
    Gilesy Elite Member
    love a bit of Gold!
  20. Scott
    Scott Active Member
    Let us no how the bike feels before and after the linkages
