Tyre profile, 50 or 55?
Discussion in 'General 1000RR Discussion' started by sinewave, Apr 4, 2013.
  1. BlackDevil
    BlackDevil God Like
  2. BlackDevil
    BlackDevil God Like
  3. sinewave
    My 55 performed faultlessly at Darley Moore especially hard on the anchors!
    #23 sinewave, Aug 21, 2013
  4. f1nn
    f1nn Active Member
    I've just fitted 190/55 Dunlop gp212 Pro, and I'm really impressed.
    The only downside is the rear is catching very slightly an the underside of the hugger, but nothing a washer or two wouldn't fix
  5. BLAGGERS
    BLAGGERS Well-Known Member
    i noticed the 55 tipped in a lot faster on track, more than i noticed on the road.
  6. sinewave
    Yeah, mine too, you can just see the small dark patch on the underside of the Hugger where it's 'Kissing' the underside probably due to expansion at Ton + speeds!!
    Pic was taken 50 miles after initial fitment hence the Chicken Strips! ;)
    Can't be arsed to remedy it as it's so slight!
  7. navvy10
    navvy10 Well-Known Member
    I'm going to try the 55 profile and the DRC's next month when my Michelins wear out :D
  8. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I had the DRC's on my blade when I bought it, I've got Roadsmarts 2s on it now and honestly the grip between the two is negligable on the road. You can still get the KD easily on the sport touring tyres and they last so much longer, if you ride regularly or commute, go for sport touring tyres. The DRC's are good if you're a very spirited weekend rider in the twisties but honestly I'd say try the roadsmart 2s for the road riding, they are much more inspiring in the wet than the DRC's were...
  9. Scott
    Scott Active Member
    60's!
  10. navvy10
    I don't ride in the wet tyke I have real respect for my bike.... ;)
    That and I know it's not getting a fairing off clean every couple of weeks
  11. mekanix
    mekanix Active Member
    Definitely go with the 55, faster turn in and better grip. I can't see any negatives for having he higher profile. I'm running a 200 which makes a massive difference.
  12. BlackDevil
    BlackDevil God Like
    Your running a 200/55 on a Fireblade ?
    For Race or Street riding?
    I thought that a 200 wouldn't fit?
  13. mekanix
    Indeed I am, on the road mate. I checked with Pirelli before I bought them cos I run supercorsas and they no longer make them in a 190 and didn't wanna drop to a 180. Went straight on, still plenty of room and handles brilliantly.
  14. sinewave
  15. mekanix
    Will get some on later or tomorrow mate. Looks massive in comparison, looks pretty menacing.
  16. sinewave
    200/55/zr17 Rear Road and Track Tyre
    Original Equipment on the Ducati Panigale, the new SP Version 2 Diablo Supercorsa features the same tread design used in the 2012 World Superstock 1000 championship. High modulus fiber carcass offers a lower deformation ratio and makes the entire structure stiffer to allow a better synergy between compounds and tire carcass. Single Element Tread Pattern permits a 24% larger slick shoulder area (vs. previous Diablo Supercorsa), increasing contact area and grip and wear regularity. New compounds offer great balance of mileage and grip in an ultra-high-performance product. Rear tire uses Pirelli's patented EPT (enhanced patch technology) matched with a tri-zone compound that helps optimize the contact patch for improved grip and handling.(W)-rated for speeds of 168+ MPH
    OE for Ducati 1199 Panigale & Aprilia RSV4
    Spose it'll do for me little owd Blade eh?
    :eek:
  17. SimonRR
    SimonRR God Like
    Does the 10mm extra ride hight on the rear make much of a difference?
    Thinking of trying the 55 profile myself, Will tyre warmers still fit under the standard 05 hugger?
    Get some pics up Mekanix please
  18. lambchops
    lambchops Elite Member
    pics please i want to see this beast too! :)
  19. Black
    Black Active Member
    Just remember the 55 isn't a dimension as such, but a percentage of the width. So a 200 55 has a diameter 30mm bigger than the standard fitment. That's assuming the width of the rim allows the correct profile when inflated.
    At least that's my understanding.
    I'm running 190 55 which has a diameter 19mm bigger than standard. I like it but many cant feel the difference other than taller seat height.
  20. SimonRR
    SimonRR God Like
    Can you actually feel the extra 9.5mm increase in ride hight?
    Does that hight at the back upset the geometry at all?
