Tyres again
Discussion in 'Maintenance' started by stujacks, May 26, 2014.
  1. stujacks
    stujacks Active Member
  2. The.kickboxer
    The.kickboxer Active Member
    Since when has someone rejected grip over looks?
    Got a 55 on mine with a repsol hugger no problem. Also its a Continental Sport Attack 2, better than any Pirrelli iv had.
    #22 The.kickboxer, May 28, 2014
  3. stujacks
    Hi The Kickboxer
    Would I really notice the difference between the 2 profiles.
    Cheers Stu
  4. sinewave
    Yep 55 profile on mine also.
    Does ever so slightly 'Kiss' the underside of the OEM Honda Hugger at 120mph+ speeds due to Tyre Growth when new but it's not a problem and stops once it's worn a bit.
    All the 55's do it on the OEM Hugger and it's nothing to worry about at all.
  5. stujacks
    Hi Glenn 12 how did you find the services of tyre leader
    Cheers Stu
  6. Ian E
    Ian E Active Member
    I've used Tyre Leader a few times now and found them good - quick delivery and best prices. I used to use Oponeo and Mytyres but Tyre Leader are cheaper.
  7. stujacks
    Cheers Ian E
    Am I right in saying they are a German firm and if so are their tyres the same spec as in the UK.
    Cheers Stu
  8. Ian E
    Ian E Active Member
    It says German on the web site, but I think all the tyres I have bought from them have been despatched from France. I normally order at the weekend and the tyres have arrived by the following Wednesday. I've had a number of tyres from them (Pilot Power 3, Pilot Road 3, Metzeler Racetec etc.) - all fine. Mates have bought car tyres from them and made big savings. Same spec as UK - I think the Michelins are made in Spain anyway (from what I can remember)
  9. stujacks
    Cheers Ian E
    Tyres now ordered
    Thanks Stu
  10. bandit_287
    bandit_287 Active Member
    My rear sportsmart is at the wear limit in the centre of the tyre but got loads of tread left still on the outer edges. I need to lean more lol.
    I'm going to replace it with the sportsmart 2 next month as the front sportsmart still has loads of tread left.
  11. julestys
    julestys Active Member
    Dilemma
    Question is do I have enough on my Bridgestone S20 to get to Assen and back, which is around 1,000 miles.
    Don't want to really put another tyre on that will definitely flat spot, or do I go for Road Pilot 4's to be on the safe side??
  12. sinewave
    At the sides ya do but the center is getting low and not good for a torrential downpour on a motorway etc
    PR4 time IMHO!
  13. Nick_BladeRR
    Nick_BladeRR Active Member
    What sinewave said and remember.... Hip to be square.jpg :D
  14. Kentblade
    Kentblade God Like
    Looks like that will give a 2 stage tip in, flatter than a pancake
  15. julestys
    Yeh I guess thats the problem doing a lot of touring around on a soft tyre like the S20
    Getting to Dover is all motorway and so not much can be done run getting a flat spot, short of weaving my way down south!
    New rear tyre being fitted on Tuesday.
    Going to give the Evo a go as the front is fine.
    After that I will do front and rear RP4
    Have a soft spot for the Brigestones, excuse the pun
  16. julestys
    Thank you
  17. chicken0365
    chicken0365 Active Member
    Hi Sinewave. My Bridgestone S020's that came on my 2013 blade are almost at the end of their life and I'm looking for a replacement. Bearing in mind I don't take my bike to the track would you say the PR4 is the best road tyre out there?
  18. HRCTrev09
    HRCTrev09 Well-Known Member
    I've heard really good things about Metzeler M7 RR's MCN tested them back to back with the epic Sportsmart2 and the M7's clinched it due to feel and comfort just donno how long they'll last! But the good news is ColinBR has a set on his Blade and we shall find out no doubt ;)
  19. daz1
    daz1 Active Member
    theys puppies turned up today akropovic 2 010.jpg akropovic 2 007.jpg £235 dell orderd 16.00 on friday came today
    #39 daz1, Jul 7, 2014
  20. ColinBR
    I'll put them to the test this weekend in Spain mate :)
