Wd-40
Discussion in 'General 1000RR Discussion' started by hump333, Mar 2, 2013.
  1. ray
    ray Well-Known Member
    I have heard conflicting stories about using WD40 for cleaning the chain though?
  2. phantom
    phantom Active Member
    the makers say its 100% safe for chains and bearing cleaning.I use it and the muc-off stuff to clean my chains
    and have never had any problems.
  3. phantom
    p.s they just say make sure to lubricate them after as wd40 isnt a lubricant.
  4. lambeth longshanks
    Boss white and hemp - catnip for gasmen!
  5. phantom
  6. BoroRich
    BoroRich Elite Member
    WD40 is one of my favourite smells in the world :D
    I sometimes use it for cleaning the bike but I've heard it that it dries out the o-rings on a bike chain, shrinks them and allows the internal chain grease to escape.
  7. phantom
    I had heard that too but the makers say this is a myth.
    I have gt85, basically the same stuff and it says to use
    it on chains and bearings.I got it free with my new mountain bike.
  8. kpone
    I know there's Teflon in GT85 but I don't think I'd rely on it for anything but light duties as a lubricant. To induce decent slippage, yes, but not as a lube.
    Soak a cloth in it then run the iron over it and it makes it a lot easier to do the pleats on your frocks.
  9. phantom
    I dont use it as a lubricant, I use it to clean then use castrol wax to re-lube the chain.
  10. rollsroyce
    rollsroyce Member
    Hi just got back from Aldi they have wd40 on offer, got meself one for £1-99 with extra 50ml.
  11. SIDEWAYS
    SIDEWAYS Senior Member
    I use and only use GT85 on everything I service and clean mechanically.Use it at home and work.The reason I use GT85 is that it has ptfe in it that stops rust developing by giving whatever you spray on a light coat of ptfe.I use it at home cleaning blade,guns and car.Work I use it for servicing cars, pushbikes even the counter.WD40 is American GT85 is made in UK by GT85 ltd in Guildford.I find GT85 lasts a lot longer at keeping rust at bay than WD40 and goes further.Wd40 is donkeys years old although good but not as good as the new stuff out there today.
  12. jokeshopbeard
    jokeshopbeard Active Member
  13. hump333
    hump333 Member
    Wd 40 cleaned my wheels a treat an belly panel today that chain wax is a load of crap its gets everywhere plus brack dust.
