Another web site you could find useful? What TowCar.com - All about Towcars and Towing Caravans Now you will here a lot about tow weights and the 85% rule, I'm not even going to get into that here, mainly because it's the opinion and arsehole syndrome. And should be left to caravan forums. You can get caught out with tow weights but if a manufacturer states you can pull 2000kg then that's all well and good. Just make sure the engine is up to the job expected of it, there's nothing worse than someone towing when they come past and nearly crawl up the next hill. I towed all 1800kg wobble box plus full car up to Glencoe in August with the X Trail it did not miss a beat.
