  1. mr.h
    mr.h Active Member
  2. callumw
    callumw Active Member
    Put some WD40 in the tank lock after having a bit of a moment at the petrol station.
    Working fine now :rolleyes:
    Did the steering and tail locks whilst I had the can out at it + lubed the chain with some Wurth as it was overdue and beginning to bind a wee bit
  3. Jase
    Jase Elite Member
    Booked it in next Tuesday for a pc5 and K+n air filter then a dyno run with custom map then doing a track day on the Wednesday at Oulton park .See if I notice any difference .:D
  4. hump333
    hump333 Member
    Moved the hid ballast from under seat to the side fairing & tidy up the wiring[​IMG][​IMG]
  5. Clarkey
    Clarkey Member
    Cleaned my garage out so I've got more room
    And fitted my ASV levers thanks to ColinBR
    So had a good day
  6. dessp2
    dessp2 Well-Known Member
    Tried to fit stomp grip and royally fooked it up. I prepped the surface, had the hair dryer at hand then got to work. One side stretched too far on one side, the other side miss aligned. Problem is with stomp grip you have to get it right first time or that's it. Tried taking it off and starting again but it looked wank so had to take the lot off and in the bin it went. £40 down the pan. Gutted
  7. Phil.O
    Phil.O Member
    Got it MOT'd and had some fun getting there and back :)
  8. Gblade
    Gblade Active Member
    Fitted a power commander and 02 eliminator, maps all loaded and ready for a test flight ASAP!
  9. martinowen
    Twin lights
    #1989 martinowen, Apr 11, 2013
  10. MrB
    MrB God Like
  11. Clarkey
    Clarkey Member
    Well nothing but just had my K&N filter delivered
    So now waiting for a chance to pop out in between
    Decorating so thinking of a good excuse to go out there
    Without my Wife knowing !!!!!!
  12. Clarkey
    Clarkey Member
    Nice garage
  13. cbr1
    cbr1 Active Member
    tip of the day DO NOT SPEND BEST PART OF 2 HOURS TAKING YOUR FAIRINGS OFF to fit none cut fairin crash bobbins when there is NO fecken need too. got them of ebay no instructions :mad:
  14. hump333
    hump333 Member
    Cbr1 as it says on the title "none cut crash bobbins" lol :)
  15. lee711
    lee711 Active Member
  16. sinewave
    From what I've been told (Dealer did mine) you don't need to remove the fairings to fit the drilled R&G ones either.
    Just loosen enough fixings so that the fairing can be 'pricked' on the inside to enable a mark to be left to enable drilling.
    Top Tip is use a Cone Cutter and not a Hole Saw for a neater finish! :D
  17. phantom
    phantom Active Member
    I used a hole saw as you wont see the hole anyway.
    I loosened mine but the ram air popped out so was a royal
    pain getting it put back in.
  18. derick
    derick Active Member
    Fitted a zero gravity seat. Looked at it and the went back into the house. Be at least Monday till I can get on it as away for the weekend.
  19. thefirebloke
    thefirebloke Elite Member
    Changed the oil in my 08 blade and felt so guilty after reading about rusty chains and cleaning them that I set to on my own :rolleyes:
  20. dave d
    dave d Elite Member
    Shamed you into it T AND DONT FORGET TO CLEAN BEHIND THE ADJUSTER lol
