  1. Haggler ®™
    Haggler ®™ Active Member
    The Blade went away on her Holibobs..................she sent me a "Wish U were here" postcard!!!
    Darren @ MCT is playing with her .....lucky fuc*er!
  2. chicken0365
    chicken0365 Active Member
    Took my blade to Race Lab in Bournemouth where Paul tuned the suspension to my body profile and riding style. He did an excellent job explaining each step and adjustment in detail to give me the understanding of how the adjustments effect the dynamics of the bike. Paul specialises in suspension tuning and also works with gearlink kawasaki in British Supersport. Well worth the visit.
  3. Bloy182
    Bloy182 Active Member
    What did i do to my blade today?
    I fitted a set of front brake pads; a set as in all 4 not 2 as I previously ordered, doh!
    I also tried to remove the "warning" stickers from the tank and swing arm. I gave up pretty soon as i realize i will need a bloody heat gun!
  4. graemewalker
    graemewalker Elite Member
    Use a hair drier dooh
  5. Bloy182
    TY, will do when i have a spare hour :D
  6. Alblade
    Alblade God Like
    Rubbed flakey paint off sides of rad and guard ready for painting in Satin Black hamerite
    Washed bodywork down ready for re-fitting tomorrow
    Removed snitcher so need to shrink wrap the end of old cables.
  7. Alblade
    Alblade God Like
    Electrics sorted for removed snitcher, Tail unit back on, fairings cleaned up and one infill panel re-fitted correctly so gap now gone (annoyed me for a year that)
    Rad and guard painted, just waiting for them to dry before fans go back on rad and re-fit, replace coolant then when testing / bleeding it get ready for oil change.
    Lots of photos taken so show changes made / clean up.
  8. Kentblade
    Kentblade God Like
    Washed my bike again this year, topped up the oil, adjusted the chain for the second time recently, so it's on its way out, put some air in the tyres as they were a bit scabby, and finally got around to greasing the side stand pivot so that it goes back too where it should.
    Mopped some scuffs and marks of the tank that were starting to annoy me.
    Time for a celebratory beer I feel.
  9. Stumoores
    Stumoores New Member
    Diagnosed my battery charging fault
  10. el-nicko
    el-nicko Well-Known Member
    snitcher?
  11. Wozza
    Wozza Elite Member
    Hi how much did it cost for the set up?
    Many thanks
    Wozza
  12. Haggler ®™
    What?..............At MCT?
  13. SimonRR
    SimonRR God Like
    Took me both wheels and checked bearings (all ok) cleaned bike while in bits :)
    Put on -1 front sprocket, and cleaned and checked rear sprocket and chain (all ok)
    Recalibrated speedo healer for gearing change
    Changed coolant as its been two years
    Took brake calipers off and gave a good clean and checked pads (all ok)
    Next I have to do air filter, plugs and valve clearances
    And a few smaller bits and they she ready for 2014
  14. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Moved my rearsets to fit me properly, took me and a mate 3 hours to get a bolt out!!! Why do people over tighten things???? Also took play out of the throttle so shes ready to rock and roll at cadwell next sunday!
  15. Skippy79
    Skippy79 Active Member
    play out of the throttle? your well nuts, 2mm or so is just right. I tested a gsxr750 K5 over in spain without play and someone will fall off that bike this year due to a highsider I can tell you ;)
    a 600 is less forgiving, but no play is mental, you might as well ride with an on/off switch and leave the throttle stuck open :D :D
  16. glynn
    glynn Member
    Took my brake callipers off and found that only 3 of the 8 pistons were working. Taken them to my mate to strip em down and sort. Thought the braking was odd last time i rode it!!! Got new front discs and pads to fit on friday.
  17. chicken0365
    Took my Yoshi R77 off....why....because the baffle screw fell inside when I was removing it. Damn! But at least I know I'm not the only one who has done this.
  18. Bloy182
    Done it Saturday, but i fished it out with a magnet whoop whoop
  19. el-nicko
    How old's your bike glynn?
    Nick.
  20. ShinySideUp
    ShinySideUp Elite Member
    Well I finally got my butt in gear to get some overdue winter maintenance started and tonight I cleared the workbench in order to get everything ready for the front end upgrades that’s getting done on both my own bike and ColinBr's Blade for the soon approaching season, got the forks off mine already just need to actually find time (ear marked for the morra nite) to strip them down and swap the new parts over!
    I am doing mine first to make sure I have taken all the tools required up with us when we tackle Colin’s bike over the weekend in his less equipped for the moment "Man Cave".
