  1. M3NTALIST
    M3NTALIST New Member
    Today I had a bash at repairing a leak from the clutch cover, I've left the engine dry to give the smeg a good chance to set so hopefully all sealed when I give it some fresh oil tomorrow (fingers crossed).
    Andy B
  2. Jkaye
    Jkaye Active Member
    Is this on the 09 Repsol mate? if it is I'd be bouncing the bike back pal.
  3. rich918
    rich918 New Member
    I took all the fairing off polish the engine up ,clean the insides of the fairing , and somebody put new down pipes on strainless steel one on ,
  4. M3NTALIST
    Yeah that's the one mate.
    Taking it back is a bit drastic for a free to fix oil leak though lol.
    Andy B
  5. Blackness
    Blackness Active Member
    Today was oil change day ! Should be a simple, relaxing kinda job, but no... The feckin lower fairing bolts didn't want to play ball and the stupid rubber nut thingy just wanted to spin, and its too short to really get a good grip on it with anything :/
    Must have been a good hour of trying various pliers and grips, grazed knuckles, walking away cursing, walking back trying again, wd40, tea, fags and so on before i gave up !
    Lucky it was just the front lower off side bolt that was stuck, so with all the others out on the right side i could pull the fairing away enough to get the oil filter changed ! Mission !! Has anyone got any tricks to getting them bolts out ??
    I went for Castrol Power 1 Racing 10/30, although the guy in honda shop where i picked the filter up from said i should use a semi synthetic !?
    Also i fitted some dark tint headlight protectors ! Probably not the best safety option but does look meaner :) !!
  6. travellingkiwi
    travellingkiwi Active Member
    You think? Personally I like to think when I pay for something all the niggles have been either declared or sorted...
    H
  7. M3NTALIST
    It was declared.
    Andy B
  8. Slow and fast
    Slow and fast New Member
    Change shock absorber for a different one and discovered why people uhm an err about putting different years of shock on different year bike, but importantly with some violence, crying and begging it fit, also bled front brake and discovered new problem, bike isnt idling at 11,000 RPM and the screw to adjust idle wont turn :S
  9. thezipsteruk
    thezipsteruk Elite Member
    Added the power supply i took from my repsol onto my new blade and installed the ram mount into the stem.
    Also took out every single fairing bolt out and added ally grease to them so they don't cause the aggro blackness had a few posts up :)
    I remember the grief from last time! :)
  10. Bryan01
    Bryan01 Active Member
    Nothing to the bike except pull it out of the garage and look at it.
    Did replace the 2 lower suspension control arm and rear bushes on the car :confused:
  11. Jbully_uk
    Jbully_uk New Member
    PHP:
    Zero gravity corsa screen, New hel lines on Saturday and then remove the pads and all the winter **** that totally jammed the pads up so that they would move at all, I have decided that she's to sexy a bike to ride in the winter with all the crud on the road. Looks like I'm going to have to replace the pistons with all the pitting and damage to them, oh and a white blue and red power bronze seat fitted as well.
  12. Alblade
    Alblade God Like
    Took the current lump of parts and an engine away in a van at the weekend
  13. Womblewizard
    Womblewizard Active Member
    Had the same problem managed to get it off in the end by pressing on the back with my finger and screw driver while turning the allen key pushing rubber through fixings eventually came out with rubber still on the back split but at least I can remove it now and replace nut. bloody pain :mad::mad::mad:
  14. rich918
    rich918 New Member
    went for a run round got back and took the rear foot rest off and put one on which I make up for the exhaust side ,looks a lot better ;)
  15. Gilesy
    Gilesy Elite Member
  16. Souleh
    Souleh Active Member
    Rusty as ****! 7 months off the bike :eek:
  17. explorer
    explorer Member
    Me and my son took our bikes for breakfast today at the ponderosa cafe, great day for it.
  18. Dano28
    Dano28 Active Member
    Looks and sounds good explorer!
  19. Barstewardsquad
    Tax disc off, number plate off, headlight disconnected, dark light protectors on, mirrors off and blanking plates fitted, and chain tightened. Nearly ready for Blyton on friday :)
  20. BlackDevil
    BlackDevil God Like
    Do I see a HP4 on the picture ?
