  1. exfire
    exfire Elite Member
    Yes it would mate, your rear end looks great....the bikes of course before you get worried lol. I have been tempted so many times but where do I stop..........I am an addict.....there, I have admitted it.....am I cured now ?
    I am always banging on about being a bit of a purist rider, but the lure of a quickshifter is getting almost too strong, if I do it will be the Cordona as the garage i use swear by them and he won't fit anything else.
    I really really want a custom paint job, something different, something unique, but it is a hard thing to get right and it is a lot of dosh.
  2. RedBull
    RedBull Member
    HID Projectors on the RebBull
    Finally got round to installing them. It's not straight forward as plug and play, you need some electrical know-how...or Google/YouTube.
    I added 2 switches too. This enabled me to turn either the projector headlights or the angel eyes off independently
    #4142 RedBull, Aug 16, 2014
  3. Barstewardsquad
    Wife put the heatshield on the new belly pan for me, and I got it fitted with nice new scrivets. Reassembled and fitted the new cone and then improvised a fitting to the front indicators as the last owner had glued them on as there was not bolt/stud on them. I managed to glue a screw rivet insert on which should hold it until I can sort a proper set of indicators. Also made up some indicator leads using Tamiya connectors to replace the iffy bullet connectors, with the added advantage on a longer lead which should help when the fairings are off. Would have had the fairings on as well but managed to misplace an indicator :eek:
    Also decided not to drill the fairings for the R&Gs and so I played hunt the thimble for the original engine bolts. Found it in the end and got them nicely torqued up.
  4. Barstewardsquad
    Finished putting new fairings onto the bike, then it rained so I sulked as wanted to take her out for a spin. Not been on her since I slid her down the track on 18th July.
    #4144 Barstewardsquad, Aug 17, 2014
  5. Jimbo Vills
    I didn't crash mine! Unlike yesterday.... ;)
  6. Lazywaster
    Lazywaster New Member
    RedBull - did you have to cut into the headlight cluster? What HID did you use? Is it worth the aggro?
    I'm really thinking of the conversion but have heard its a bit of a mare
  7. Knxwledge
    Knxwledge New Member
    Installed R6 Throttle Tube
    Working on the 600
    #4147 Knxwledge, Aug 19, 2014
  8. RedBull
    RedBull Member
    Hi. I'll try and be as informative as possible without rambling.
    Like you and many others I too have spent months combing the internet, looking for a reputable company who weren't from the USA or China, eventually I found one in Europe.
    I purchased a full installation kit from them.
    2 Brand new 35 Watt ballasts
    2 Brand new Mini H1 Bi-xenon projectors
    2 Brand new Mini shrouds
    2 Brand new H1 xenon bulbs
    1 Brand new plug & play Bi-xenon relay wiring harness - (not used for the motorbike conversion)
    Mounting brackets for the ballasts
    2 Year warranty
    Free personal customer support from
    Additionally I had to purchase from them:
    The metal mounting plates for my type of bike.
    Angel eyes
    Delivery - (7 Days)
    Total £248
    Installation. I wanted two switches to independently turn off/on the projectors and angel eyes. I purchased from Ebay 2 12V rocker switches for £5
    1. I took off both fairings. seat. front headlight fairing with headlight assembly.
    2. removed headlight assembly completely from fairing.
    3. placed headlight assembly into oven. Mine is fan assisted so I put it on 100C for 3 mins, checked and replaced for another 2mins. Better to be slow and safe than a melted mess.
    4. Took out the reflective housing by fully unscrewing the adjustment bolts. the ones that make it go up down left and right.
    5. Fitted the projectors to mount then installed the mount onto the existing adjustment bolts. - fully screw them on all the way down
    6. replace in the oven and repeat step 3.
    7. The wiring loom I threaded through the faring, under the tank up into the battery
    8. 1 Hid Ballast I fitted in the left side faring. the other sits nicely on the side of the centre metal frame work. - see pic.
    9. its just a case of hiding the wires to suit your bike.
    switches.
    12V rocker switch has 3 pins.
    1st: + from the light source.
    2nd: +from power source (battery)
    3rd: Earth from both sources.
    There's lots of diagrams on Google - its very easy to do. I purchased some electrical spade connectors to mount the flex (electrical cable) onto the switch. I already have some spare electrical flex from an old electric lawn mower. I'm not an electrician, I learned from the master. Google and YouTube...lol
    In earnest its not that hard, but its easy to mess up, which is when it becomes costly. I melted an after-market headlight assembly... £100 down the drain :(
    You do have to to a bit of splicing, make the wiring looms for the switches and think outside the box when problem solving. The scariest part was drilling 2x 20CM holes in my fairing for the switches...you only get one chance at getting that right....lol
    The actual black OEM plugs that fit onto the OEM H7 lights, I haven't touched these. I made extension cables using the flex an spade connectors. So at any time I can revert back to my stock headlights. All i have to do is step 3 and replace the reflective housing + bulbs.
    I have a good rapor with the HID company in Europe and I'm confident of putting together a complete Projector kit. I may start making and selling them myself.
    The Angel eyes just slot into the shrouds around the projectors. The wiring loom for this connects straight to the batter via the 2nd switch. - its very simple.
    I hope this help is some way, shape or form?
    David.
    PS - I'll try and take some pics and post them up here later.
    here are a few new ones I took yesterday as I'm selling my bike. DSC_0197.jpg DSC_0199.jpg DSC_0175.jpg
  9. RedBull
    RedBull Member
    More pics
    2nd HID Ballast mounted position.
  10. RedBull
    RedBull Member
    The untouched stock connectors.
    This is the high beam connector. I've yet to connect this one up to the projectors as I'm waiting for a part.
    The low beam is completed but tucked away and hidden. I made little extensions using the spade connectors in the next picture. This give the projectors the power needed from the bike, but I can also revert back to the stock headlights in the future if required. image.jpg
  11. RedBull
    RedBull Member
    Connectors I used. The black rocker switch is from and old Lawnmower; it's just an example of what the pins look like.
    Blue connectors used to connect to the stock headlight plug - see pic above
    Red connects to the rocker switch pins
    The others are examples of connectors that can connect two image.jpg image.jpg wires together to make one
  12. And7rp2
    And7rp2 Elite Member
    Fitted a new R77
    Have to say these carbon yoshimuras do make a lovely noise,deep growl love it :cool:
    Racefit was the most MotoGP like but bloody hell it was loud !!
    So after having the standard ( with flapper disconnected ) which was a relief to my ear drums,sounded a bit crap really.
  13. BlackDevil
    BlackDevil God Like
    Guys!
    I think we should meet each other in Poole and “RedBull” will
    Install our HID Projectors.
    He is the Expert and we don’t like to do things wrong, do we?
  14. RedBull
    RedBull Member
    Unfortunately I'm now located in Plymouth. If anyone is from there and fancies a ride out or a coffee down at "Captain Jaspers" then drop me a line.
  15. Lazywaster
    RedBull
    Thanks for your great explanation with pics. I really appreciate you taking time to post this.
    It would be worth a ride to Plymouth just to have you're experience on hand to oversee an installation! And I think you're right, you could be onto something here with kits.
    Cheers mate
  16. RedBull
    RedBull Member
    Hello all.
    I've priced up what it would cost to start making these wiring looms and selling the HID projector kits too.
    Note - The company that supplied mine are very good. Great product, fabulous customer service & they email back within the same day, if not sooner.
    My completed wiring looms enable the HID Projectors and Angel Eyes to be turned off and on independently.
    I'm still waiting for my high beam wiring loom from Europe, which should have came with the kit. Once it arrives I'll see if I need to alter it to suit my bike? If so I'll price that up separately and included that in the total price.
    A full Kit. includes the following:
    2 Brand new mini 35 Watt ballasts
    2 Brand new shrouds
    2 Brand new H1 xenon bulbs (choose colour temp from 4300K 5000K 6000K)
    2 Mounting plates
    2 LED angel eyes
    2 Year warranty
    Free personal customer support from the European company who makes these kits.
    1 Angel eye wiring loom
    1 HID low beam loom
    1 19MM drill bit
    1 Electrical tape
    20 3M sticky Velcro pads
    Total (not including the High beam loom)
    £315 Inclusive of UK UPS delivery.
    If you wanted a separate headlight assembly with full installation? (Highly recommended) You're probably talking around the £100+ mark. I'd only ever use genuine OEM parts...After market parts are not worth the agro - As I found out when I melted mine in the oven :( Or if you have a spare, send me yours in the post.
    Finally. If you just wanted the HID Projector kit without the Angel Eyes from the company + mounting plates + delivery £240
    Regards
    David
    AKA - RedBull
  17. RedBull
    RedBull Member
    Started a new thread on this subject
    http://1000rr.co.uk/mods-upgrades-accessories-products/20433.htm
    Good news. I have just spoken with the European company. They are willing to offer a substantive discount for the first 5 orders. 17% off
    Full Hid Projector kit including mounts and delivery.
    £199 massive 17% OFF!
    (no angel eyes or wiring looms - just the full kits)
    2 brand new Mini H1 Bi-xenon projectors
    2 brand new 35W Slim ballasts
    2 brand new shrouds
    2 brand new H1 xenon bulbs - (4300K,5000k,6000k)
    2 mouting brackets including fixings
    1 H7 motor wire harness with double ballast output
    1 H7 high beam solenoid splitter
    2 year warranty
    Free personal customer support.
    ____________________________
    Motorbike mounts they definitely make:
    CBR600RR 2002 - 2006, 2006 - 20012
    CBR1000RR 2006 - My bike I'm sure this mount will fit other years before they changed the headlight looks.
    CBR1000RR blackbird
    They make the mounts in-house. So please message me your bike model and year. This way i can ask and have 100% certainty before you purchase.
    Regards
    David
    #4157 RedBull, Aug 21, 2014
  18. Hondaboy63
    Hondaboy63 Active Member
    The 3 blades
    image.jpg Never really done much apart from getting my new blade. image.jpg image.jpg
    Need to start getting some additions :D
    #4158 Hondaboy63, Aug 21, 2014
  19. andyb525
    andyb525 Active Member
    Ok it wasn't today. Maybe a couple days ago.
    Got my SP seat cowl back from the painters so I swapped out the old one then went for a blast with my brother. :D
  20. si1000repsol
    The bike looks awesome
