  1. Andrew
    Andrew Active Member
    Yeah come on we all need to see what you've used and how!!
  2. kpone
    Caned it.
  3. Tom68
    Tom68 Active Member
    Oil and filter change and fitted those cheap trak tech levers from m and p, look and feel the same as the more expensive ones.
  4. BlackDevil
    BlackDevil God Like
    That's looks really good. Probably 17 GBP materials and 8 hours work?
  5. Freedom of choice
    Thanks Bats, Still not sure, my link pipe looks different to yours and the is no way I could slide it on as I have the big bulbous section, only way was to undo the bolt and then it wont go back in as the pipe is to big. Been to busy today to have another go at, will update, thanks so far guys.
  6. ColinBR
    The threaded insert that the screw goes into on the gubilee clip could be on the wrong way. Mine was, if you make sure that the end that doesn't have a recess before the thread starts is closest to the screw that will give you a couple of more threads so you can loosen it and slide it round. It is a bit fiddly but trust me it works :)
  7. Benn The Pig
    Missed them both while I was stuck at pissin work :-(
  8. Dave V
    Dave V Elite Member
    Cheers dudes. Got a sheet of the meshed metal from B&Q, went for something not too stiff but stiff enough, if that makes sense?
    On the sides of the rad is a recess. Measured and cut the mesh with a dremal to fit inside this, length wise I cut it a little long. Bent the mental into place, slotting it into the sides. With the mesh in place trimmed the length leaving a little extra and then using a small pin hammer worked the mesh over the lips at the top and bottom. From start to finish around 5 hours, lol think the longest part was removing and fitting the fairings!!! I've got HID's fitted, re fitting the wiring and ballast is a real pain in the arse.
  9. megawatt
    megawatt Well-Known Member
    Top job Dave
  10. Benn The Pig
    Rode it to work :)
  11. Swiss T
    Swiss T Active Member
    I have put the pics on a new thread :)
  12. kpone
    Missed it.
    Especially after yesterday morning.
  13. Benn The Pig
    Not mine but booked a test ride on a Harley Vrod muscle and a S1000RR
  14. ColinBR
    Did you just say Harley. Have you not seen the slagging megawatt took last night ???? ;)
  15. megawatt
    Bought my Blade back for a tenner, so took it out in the sunshine todat and made sure it was OK at full throttle. It's fine thanks;)
  16. kpone
    A tenner!
    They saw you coming. lol
  17. megawatt
    I threatened to come back with my mates Sons of Anadin, so they took pity on me . Nice eh ?
  18. kpone
    Lmfao!
  19. megawatt
    LMFAO ? I'm sexy and I know it ???
  20. kpone
    Laughed my fornicating arse off.
    In fact, as I read it a little bit of ice cream I was eating may have come out of my nose.
