  1. Barstewardsquad
    Torqued up the new brake and clutch hoses. Bled the lot of them, well except for the front which for some reason is being a sod. It's OK if I have the lever on 6, but crap down at 3. Think I'll get the missus to give me a hand tomorrow and do it the old fashioned way as it doesn't want to work with a vacuum pump.
  2. Bryan01
    Bryan01 Active Member
    Stuck my vacuum pump back in the box and did mine the old fashioned and for good measure tie wrapped them open overnight.
  3. hondahead1000
    hondahead1000 New Member
    She should be good for backing into corners now as original is crap, looks the part too.....very nice
  4. Womblewizard
    Womblewizard Active Member
    Some Rubber on my freshly powder coated wheels! Brake Discs on, new Pads, Evans coolant done! and others bits and pieces.
    A few ticks off Boxes!
    Tomorrow get the wheels in, Bleed Brakes and tick some more boxes.
  5. Barstewardsquad
    Have left mine tied back overnight as well.
  6. Philhasasti
    Philhasasti Active Member
    Rang my local dealer back to tell them that they have fitted the wrong tyres :mad::(:eek::mad:
  7. rebel
    rebel Active Member
    Went out yesterday to take the rear foot pegs off looked at it for ten minutes then bottled it made an excuse it was to cold I'll try again some other time.
  8. Mr OCD
    Mr OCD Well-Known Member
    +1
    I really want to remove them ... But it's a proper ball ache !
  9. Bryan01
    Stop fannying about! Get in the cave and don't come out until done! :)
  10. Philhasasti
    Took me and a mate 2 hours. Its not hard really just a bit fiddly
  11. rebel
    rebel Active Member
    I'm determined to get them of for the summer iv got a abs which I think is a bit more of a pain
  12. N1xxl
    N1xxl Member
    image.jpg Further to the Harris paddock stand plates got the paddock stand in use and replaced the old paddock stand bobbins with swing arm sliders.
    #5012 N1xxl, Mar 8, 2015
  13. Kingfixer
    Kingfixer New Member
    Took off the SP Quickshifter in readiness for it going in to have the Bazzaz kit fitted, fitted a new Pipecross air filter whilst I was on.
  14. Haggler ®™
    Haggler ®™ Active Member
    Just rode it.......simples !
    First cobweb blowing session of the year and a shakedown cus the wheels have been apart.........brake judder now so sum fin int quite right......bugger
  15. Bryan01
    Forgot to mention, Went to take the bike for a test run only to find the battery was flat. So I cut the bloody grass
  16. Womblewizard
    Wheels on!
    New Pads in!
    Went to fit new caliper bolts and are 10mm to long and bottom out BALLS!. You pay a arm and leg for these and they don't even fit! But getting closer to the end.....
  17. barry107
    barry107 Active Member
    Yesterday I took off my Harris levers and fitted ASV levers in there place.
    Today I took my 2012 Balance free shock off my 09 in readiness for it to get the KTec treatment :D
  18. Barstewardsquad
    Brakes were fine today, but there was a bit of seepage around a bleed nipple so will have to double check tomorrow. Put some stickers on the bike, don't know if they are going to stay though.
  19. GappySmeg
    GappySmeg Well-Known Member
    Rebuilt my calipers, and refitted to the bike.
    Then set about bleeding them using my funky bleed hose with a non-return valve in it. Wasn't working like it did last time, couldn't work out why, then as I squeezed the lever a little more the bleed hose broke apart and sprayed brake fluid everywhere. Its on the tyres, discs, exhaust, my jumper, my face, forks, etc.......
    Turns out the valve had seized or got blocked whilst its been sat in the garage...... balls!
  20. IcarusGreen
    IcarusGreen Elite Member
    Race bike just about done, just need to add the Army stickers and a few minor bits & pieces.
    [​IMG] [​IMG] [​IMG] [​IMG]
