  1. trueuk
    trueuk Active Member
    where did you buy the number plate bracket buddy
  2. si1000repsol
    Its made by Carbomoto in Germany
  3. trueuk
    looks nice
  4. Jarryd
    Jarryd Guest
    @si1000repsol what are the torque specs like on the hollow bolts?
  5. si1000repsol
    Identical to standard
  6. Jarryd
    Jarryd Guest
    Do you torque to OEM spec or to generic specs? I.e. I always go 6mm - 10nm, 8mm - 24nm, 10mm - 37nm etc.
  7. si1000repsol
    I try to use the OEM specs with the Ti bolts
  8. Andrew Penson
    Andrew Penson Member
    Started fitting new thumb brake, need to bleed this and test this weekend !!!! image.jpeg
  9. Still at it
    Still at it Member
    Carbon the ol girl
  10. 1premix
    1premix Active Member
    Winter hibernation
    Gave the blade a really good fettle today, cleaned, greased , lubed and now all tucked up for winter. Found this little critter on the wheel. Connected the optimate patted the tank and put the cover over.
  11. Wozza
    Wozza Elite Member
    Went for its 45 point Honda Heathcheck before warranty runs out on Friday, all good needed 1tr of oil in sign Its been ridden not a oil burner! Need new tyres then went for a spin mild 15c on costa del South mad never been out like that in dec,:cool: Unreal.
  12. Haggler ®™
    Haggler ®™ Active Member
    Folded back the winter quilt............yep........still filthy from my trip to Scotland beginning of September. ......patted the tank, folded quilt back over .......night night I thought
  13. Wozza
    Wozza Elite Member
    What's all this putting the bikes away ..... I am looking forward to getting out Christmas Day the roads are quiet just got to watch out for pissed stained pensioners with presents loaded up , normally a Honda Jazz or Yaris as a weapon of choice....unless the salt comes out I'm staying out..
  14. 1premix
    I'm in on Christmas day watching my tt dvd drinking my bottle of Bushys ( and others ) then I'll spend the rest of the winter playing on my ktm 350. Keep my blade for the spring.
  15. Wozza
    Wozza Elite Member
    FairPlay I used to love my dirt bike , wish I could afford both , Have a good christmas everyone
  16. si1000repsol
    ImageUploadedByTapatalk1450363040.383050.jpg ImageUploadedByTapatalk1450363054.516768.jpg ImageUploadedByTapatalk1450363070.167390.jpg
    Fitted a few cosmetic bits.
    Real carbon tank protector and Chinese stomp grips (only £14!) not clear like the real deal but look okay. Fitted stock GBRacing cover on the bike
  17. Andrew Penson
    image.jpeg image.jpeg Got my fairings back from Alan @ RR Racepaint
  18. Shutty
    Shutty Well-Known Member
    Tinkering again, day off so sorting a very pale sad looking standard exhaust lower.
    Its no wonder they rust, a quick rub off and was down to bare metal
    Had to loosen the right footpeg to get enough exhaust movement to get to the back two allen keys against the subframe to remove the metal sleeve trim. All masked up and cleaned up and a few coats of stove paint, good for 600degrees from ebay.
    Got a carbon sleeve coming so should start to look a bit brighter.
  19. Marion
    Marion Well-Known Member
    Raining here and unable to ride so started it up in the garage and inhaled the fumes, not too much tho cos I have plans for next year !,
  20. Paul Bills
    Paul Bills New Member
    get a co detector so you can run it till the alarm sounds :b
