  1. Nickw
    Nickw Active Member
    Rode it......
    I had to go quickly to ensure the ventilation system in my jacket worked to maximum level :rolleyes:
    Nice brisk trot up through Teesdale, back through Weardale, home, cleaned, and, most importantly, Patted the tank;)
  2. dave the rave
    dave the rave Active Member
    That's the best what did you do to your bike thread I've read well done mate
  3. Phil_M
    Phil_M Active Member
    Two Bros slip-on and stomp pads fitted. Got everything put back together around 10:30 this evening, couldn't resist firing her up and OMG what a sound.....only dared run it for 10 seconds!
    Bring on the weekend!
  4. Rids666
    Rids666 Active Member
    Pics please Phil ;)
  5. Stef64212
    Stef64212 Active Member
    Fitted my charging lead for my ctek charger. First chance I've had since removing it from my old blade.
    Slightly different route due to this bike being an abs model but still the same end result.
  6. gkr
    gkr Active Member
    Finally installed the Rokform fork clamp mount for smart phone.
    I had to use one inch pipe (~50mm long) in order to lift it up to acceptable level.
    Next will be a USB power supply to be complete.
    As soon as I will get back home shall try the trackaddict application on track.
  7. Phil_M
    A couple of quick pics....the sun is shining, so time for a ride! :D
    [​IMG][/URL][/IMG] [​IMG][/URL][/IMG] IMG_0597.JPG IMG_0595.JPG
  8. danthorrr4
    danthorrr4 Active Member
    Would you recommend the two bros slip on?
  9. Phil_M
    Fit was easy, it looks great IMO, the quality appears to be very good, though obviously I have no idea about the longevity and the sound is transformed......just about the right side of obnoxious!!!
  10. Phil_M
    And the reason the stomp grips are now needed......
  11. Jandy
    Jandy Active Member
    Not so much to the bike but I was in a certain honda fireblade bsb garage at Donington park yesterday and just so happens I had something in my bag that needed signing so Jenny, Jason and Dan kindly did ;) 20160919_080314.jpg
  12. okeloon
    okeloon Active Member
    would love to hear the 2 Bros end can, any video? On a similar vein, is there already a thread on this site where contributors post vids so we can hear the different exhaust systems? I know you pick them to look good, but the be all and end all is the NOISE!
  13. ray
    ray Well-Known Member
    Insured her today.
    MOT'd her earlier in the month.
  14. kev.b
    kev.b Well-Known Member
    IMG_20160910_070117.jpg New seat cover for my 06 Blade . Saxon seats .
  15. Rids666
    Mmm I like. How much for this if you don't mind me asking?
  16. kev.b
    £59.00 www.saxonseats.co.uk
  17. TheRamJam
    TheRamJam Well-Known Member
    Replaced the the front right wheel spacer with the correct type, replaced bearings and seals too. Gave the front calipers a good clean, removing all the crud from the pistons.
  18. Barstewardsquad
    Replaced HID bulbs; checked oil; checked coolant; checked chain; checked tyres; checked indicators and brake lights. Warmed her up, started at first press, and after fan kicked in checked the oil again. After months of working away and weekends of house renovation I finally have some time to myself over the next 2 weeks and I am going to convert petrol in to sound :)
    That's if I make it to the petrol station as the reserve light is on :eek:
  19. Muffking
    A wash and an overdue chain clean on the track bike, plus switch to a larger 47T rear sprocket.
  20. Muffking
    How about Cadwell on the 17th then ;)
