  1. raphael
    raphael Elite Member
    They are pretty much Brembo as made in the same factory just own branded
  2. mk3golfcab
    mk3golfcab Elite Member
  3. Brom66
    Brom66 Well-Known Member
    TWM's Nigel, who make Ducati Performance Levers had them on my 1299, but they cost twice as much. Got them from RRP £180 iirc delivered.
    http://www.twm-sc.com/levers.html
  4. mk3golfcab
    Cheers @Brom66! Looks like I need another purchase now! Although I could machine my own?!
  5. Brom66
    Fitted a while back but the pictures I took didn't do justice, forgot I've got the evotech rad guard and axel protectors, not for getting full akra evo system:rolleyes:
  6. mk3golfcab
    A man after my own heart!
  7. raphael
    Bds on here sell them ask for mike
    • Thanks Thanks x 2
  8. Brom66
    BDS ? Funny you mention that my levers come with BDS etched on them, apparently they are the UK Importer !
    Now where is Mike ???
  9. ray
    ray Well-Known Member
    Always liked the idea of getting a Fire Storm due to not being able to afford an SP-1 or SP-2
  10. LRJimmy
    LRJimmy Active Member
    Good one @nigelrb thats a cracker for the money!!!!
    You're going to need to move the kitchen and TV upstairs before the new blade comes at this rate :rolleyes:;):D
  11. mk3golfcab
    If only triumph had pulled their finger out and got that Daytona to you today! You need to bill them for the firestorm :D
    looks like a good buy :)
  12. LRJimmy
    A true believer to the cause mate....Quick get out there, it might still be under the cover and one you forgot about :D:D:D
  13. R.M
    R.M Member
    Went for a quick blast just to keep the battery topped up. Cold & foggy and roads were greasy. Got a slight wobble trying to lift fron wheel over a crest on a bend:)
  14. PauloHRC
    PauloHRC God Like
    Nice purchase Nigel...... Remember I have plenty of room in my new garage should you run out of space ;)
  15. Manofsteel
    Manofsteel Well-Known Member
    Tsubaki chain fitted rear Renthal sprocket new OEM front sprocket and titanium rear disc bolts and sprocket nuts and bolts
    The rear sprocket and bolts alone has saved half a kilo in weight every little helps
  16. Manofsteel
    Definitely will as this year I’ve timed my bulking phase at the gym for over Xmas proper result :D
  17. blink
    blink Well-Known Member
    I got mine dirty
    I'm also glad i have a hugger, i was skeptical at first, but i can remember this time last year, a couple of people telling me that my leathers had a huge skid mark up them, since i put a hugger on, I stay clean and dry up the back.
    New leathers got a bit of attention today too :D
  18. Nigel H
    Nigel H Active Member
    My new toy came!
    Another thread here got me started on Translogic iS-4 shifters.
    Yes, I know I don't need one for just popping out to lunch with my brother but I bought one for me for Christmas.
    The first bit's done quite easily, well other than the usual left hand threads breaking my brain effect.
    I've even set the rest pedal height back to where it was before to the millimetre - like my feet will care...
    Now I need to hinge the tank up and inspect the wiring there.
  19. LRJimmy
    Good stuff @Nigel H but I think that @nigelrb may be having kittens with the photo seeing all the dirt build up from the chain ;):eek::eek::eek::D Merry Xmas mate
  20. Blade runner 1
    Blade runner 1 Elite Member
    Good effort, if you haven’t fitted the module yet it can be a bit tricky getting to the coils. I loosened off the left fairing to make it easier to access, the right side was ok to get to. Also the wires on the quick shifter module between the cylinders are quite short, so be careful and be prepared to just go and stick the kettle on and try again later. If you have fitted it already then this info maybe helpful for someone else. Enjoy:D
