  1. Empty_Ten
    Empty_Ten Active Member
    I on the other hand didnt look and ordered 2 packs so I got 4 bulbs :D, still, at least I have spares (not that I hope I need them!)
    doooooo eeeeeet! Riding home earlier from work, flicked the high beam on and it was illuminating road signs - in broad daylight!
  2. mk3golfcab
    mk3golfcab Elite Member
    If you want to sell your spares pm me bud
  3. LRJimmy
    LRJimmy Active Member
    Cheers @Boothman
    I was actually wondering if they would work with our box from Jens. After all you do get different types of LED bulbs for the house that are dimmable and those that are not.
    Good man, i will wait your invaluable info. :D:D
    • Friendly Friendly x 1
  4. Boothman
    Boothman Elite Member
    Of course, I’d forgotten that you’d also done the same headlight mod. Bit of a bummer that then - as if it works you’d need to buy your own and if it doesn’t then there’s no point in my sending them to you o_O.
    Let’s see what happens :), @LRJimmy loss may well be your gain @mk3golfcab :D
  5. LRJimmy
    Well today I had a 90 mile trip and 45 of those were on new super grippy M9RR’s. Thats how far it took to get to civilisation and back again :eek: but at last I got to play with the Translogic QS...and it’s fantastic, even 1st into 2nd was slick. :D
    The difference is night and day, I’d never realised but seeing the old Battlaxes off the rims they were well squared!!
    These M9s certainly heat up fast :)
  6. Blade runner 1
    Blade runner 1 Elite Member
    It’ll be interesting to see how you get on with the M9RR’s, I’m always interested in new tyre technology.
    The Translogic IS4 is insanely good, couldn’t be without it now.
  7. tuktuk
    tuktuk Elite Member
    Great choice LRJimmy. I'm a massive Metzeler fan boy!
    I'm using their racetec RR at the minute but would like to try the 9rr as the 7's were so good for road riding.
  8. LRJimmy
    I got them from recommendation because of the 7s so I never pushed them much on the way home. I pulled away from the fitters and did about 3 mile to a B&Q on the way back and had a feel and they were nice and toasty with that short town drive. So I think they will be proper grippy once they are scrubbed up a little :)
  9. Frazzle
    Frazzle Active Member
    Got my Puig double bubble on and played around with my recently installed HEL lines to see if I could get the near side line from touching the fork.... bloody impossible... either that's the way it has to be, the line is too short or somehow I've done it incorrectly... ideas?
  10. Empty_Ten
    0E100BEE-7AAD-4BB5-9579-A7F4F78C09C2.jpeg AF483842-D186-44F2-B0A2-9E22DAC7B6ED.jpeg
    Here’s a pic of mine if that helps. I can’t take credit for it as I had them installed by a workshop. Seems to be some extra fastenings?
  11. Frazzle
    Thanks mate.. your nearside line is much longer than mine clearly as I've used the mud guard clips (but can't get it to the central one on the triple clamp) too but have way less line than yours... I have enough flex I'm just concerned with it touching the fork leg.. (obviously not ideal..)
  12. Empty_Ten
    If it makes you feel any better mate, I have a wiring cluster underneath my lines which do touch the fork. If it wasn’t there, then the brake 9FE99DED-38B5-4D0C-8FD6-90B98C3CC29B.jpeg lines probably would touch it.
  13. Blade runner 1
    @tuktuk here is where I ended up with my shift rod
  14. Wozza
    Wozza Elite Member
    Went for a essential journey...,one hour excerise... Rolled into one....,spooky but great
  15. Stuish
    Stuish Senior Member
    Fitted quickshifter after some help from @Mr_Chin_LK thanks again :D
    Changed airfilter from OEM to a Sprint P08. The difference is mad between the two!
    Fairings still half off as waiting for oil and filter delivery.
  16. Stuish
    • Like Like x 7
  17. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    No worries,
    Glad you got it sorted Stu.
    Chin
  18. tuktuk
    tuktuk Elite Member
    Thanks to Lozzy and Blade Runner I got this thing sorted.
    I had one fitted previously but the rearsets I'm using atm have the lever mount at a different position so the rod needed some length adjusting.
    Still needs some slight fettling but I will do that on the test ride and take a couple 10mm spanners.
    Oil change tomorrow.
    • Like Like x 10
  19. DazK
    DazK Active Member
    Try some of these Frazzle?
    Cheap as owt :)
    https://www.ebay.co.uk/itm/162641329091
  20. Frazzle
    Thanks mate, I already have these though, but I think I've sussed it anyway, will wait for the weekend to redo it
