  1. Boothman
    Boothman Elite Member
    Sounds like a tired battery - from memory @blink you have a trickle charger but my 2016 lead acid still gave up after just over three years and that was always on an optimate. I went for a Lithium and new trickle charger nearly two years ago and not had an issue since. Plenty on here say that with the lithium you don’t need the trickle charger but I wen5 for one anyway.
  2. blink
    blink Well-Known Member
    Didnt think of that it turns quick enough though juat takes a bit to actually start.
    Hoping it's cheaper than the £500 quid for the bmw battery when it does need replacing
  3. Boothman
    I got a Shido LTZ7S-S and Tecmate charger from Sportsbikeshop for about £110 in total
  4. blink
    I have an oximate jobby, just need a new cable for it. Worth a try
  5. Stuish
    Stuish Senior Member
    If you are getting a Lithium battery, don't use an ordinary trickle charger. Has to be a dedicated lithium one. Just FWI
    • Agree Agree x 2
  6. raphael
    raphael Elite Member
    the bmw battery isn’t expensive it’s just all the coding to go with it.
    something simple like putting a cover on it will make a difference As it’s been a bit colder lately and the battery’s loose charge and enough to cause what you are saying.
  7. Keeef
    Keeef Active Member
    Track Day Build Continues: Removed intake flaps and associated superfluous kit on Wednesday (no pics though).
    Removed Pair Valves and fitted blanking plates today.
    20200905_143554.jpg 20200905_143533.jpg 20200905_143547.jpg 20200905_144755.jpg
    Boxed to store...
  8. blink
    that was the price for the battery, no coding, id do that part myself anyway
  9. Stuish
    If it's not a Lithium Oximate jobby, don't connect it to a lithium battery. It might work OK for a day or two, but risk of fire etc isn't worth it.
    • Agree Agree x 3
  10. Wozza
    Wozza Elite Member
    Real change in temp this morning but a good loop all round Goodwood and back came across a couple of village heros that sit right on your wheel in their cameo outfits loud happy shopper cut off cans thinking they are about to sculp a sportsbike well ruined there morning as I cleared off .....waited for my mate who was behind me and give them a nice wave and got a finger in return ....do hate the lower class..
    • Funny Funny x 5
  11. bradt
    bradt Elite Member
    Could it be the battery, do you keep battery on trickle charge ?
    Suit looks good blink..
  12. blink
    it started ok this morning, i dont keep it on charge, i ride it a couple of times a week
    Just wish i could ride it as well as I look posing with it @bradt :D
  13. bradt
    bradt Elite Member
    Might be an idea blink to keep on charge or get a new battery.
  14. Saqib
    Saqib Active Member
    Hey. Just been reading the comments on here about the battery and charging.
    This is just my opinion. I read the handbook (I know!!) on my Honda CBR650R.. and it says clearly "Charge the battery once a month if the bike is not used often".
    So I do the same with my Blade. Charge the battery once a month on a trickle charger. I just put the CTEK charger on until it tells me the battery is full. Then take it off. I've had zero issues.
    I feel the battery needs a tiny bit of cycling (allowing it to drain a little naturally) to keep it tip top.
    I agree Lithium is the way forward though. What brands do people recommend?
  15. Empty_Ten
    Empty_Ten Active Member
    I asked about this when I had my valve clearance serviced. The guy said it’s normal , it’s a very small battery for the bike it’s in. It takes between 4/5 revolutions before it starts whereas my MT10 is 1-3.
    He did a battery condition test as part of the service and it was good and nothing needed replacing.
    I made a conscious effort to try get it on an Optimate every week. At the time I bought the blade I was in a ground floor flat, I would wheel it to my window and run an optimate through the window for a couple of hours a week. Mine has an alarm on it as well which inevitably will drain some of the battery juice.
    Now that it’s in a garage, I can keep the optimate permanently.
  16. Keeef
    Keeef Active Member
    153mi essential riding today. Not too buggy:cool: 20200908_165548.jpg
    • Like Like x 6
  17. Wozza
    Wozza Elite Member
    Just washed it tonight ready to go in for service Saturday 5800m in 2 yrs so not to bad ....they called today to firm up that I am quite welcome to have the new SP for a couple of hrs ...be rude not to...
  18. Saqib
    Saqib Active Member
    Took the Blade to work yesterday (60 miles each way cross country). Really wasn't gelling with it in the morning.
    In the evening.. rode it a bit harder, and one gear lower (eg 4th gear at 60mph, 5th gear at 70mph).. and the thing just comes alive, it is so much fun. Yoshi pipe is LOUD.. going to try it with the baffle back in!
    Fuel light came on, put just over 12 litres in, as per the owners manual. Like clockwork.
  19. Stuish
    4th at 60 is one gear lower? :eek: Stick in second and have fun :D
    • Agree Agree x 5
  20. Saqib
    Saqib Active Member
    Haha.. yeah, early days on the bike!
    Overtakes in 2nd.. are hair-raising compared to the CBR650R I had previously!
