  1. phantom
    phantom Active Member
    You can stck them on top of the original badges or with some dental floss
    And a hairdryer remove the originals and stick these on.same thickness
    As a tank protector.
  2. callumw
    callumw Active Member
    Fitted my replacement left wingmirror.
    Santa came late this week (courtesy of Demon Tweeks and SportsBikeShop) and have new bits to stick on :)
  3. Jollygiant
    Jollygiant Member
    Just ordered some long ASV levers in black.
    Was debating between those and the harris ones and finally decided on the ASV's.
  4. lee711
    lee711 Active Member
    Fitted new rim stickers and stripped down, cleaned and greased the rear shock linkage.
  5. Givover
    Is that something we should be looking to do Lee ? I can't remember the age of your bike.
  6. Remal
    I took the rear CRC track fiaring off as I'm going with the standard rear end. fitted the standard one back on. hoping to buy a standard rear fairing in the next few months and spray it up to match the track fairing so it matches. Tart I know
  7. lee711
    I do it every winter mike, the shock linkage is open to being covered in crap, and has 4 moving joints each with their own roller bearing, so they can take a bit of a beating through the year. I posted else where about these bearings being susceptible to wearing and thus fail an mot so i like to keep on top and make sure all is working well, cleaned up and well greased, ( 2008 model with 26000 on the clock )
  8. phantom
    also keep an eye on your sumps around the bung
    as on the last blade site I was on there was seven member's
    with 04-07 bikes that the salt rotted holes in them.
  9. dave d
    dave d Elite Member
    i thought this was organic corrosion(the alloy plug reacting with the magnesium case)
  10. phantom
    no this was definitely due to salt.two fellas bikes started leaking oil
    as there was holes right through the sump.
    although they were out of warranty honda did replace the sumps
    as a goodwill gesture.
    I know some have had issues with the plug itself but as you can see in this
    pic bits of the sump well away from the plug are rotting through.
  11. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Today I removed the pillion pegs from my 2010 blade.. All I can say is- WHAT A FUCKING MISSION. One things for sure I am NEVER putting them back on not only does it look a hell of a lot better but it has to be the most tedious thing I've done all week :)
  12. phantom
    I want to take mine off but im sure as soon as I do the wife
    will want to go out a spin.
  13. Yorkshire Tyke
    Lol I'm sure when I'm old enough for a wife I will blagged into putting them back on! Looks really nice though would deffo suggest taking them off. No idea why honda have secured them to the inside of the subframe???
  14. eyore
    eyore Member
    Not a thing, didnt even look at it once which must be a first, too bloomin cold. Sat by the fire all day with the papers and watched rugby online.:)
  15. phantom
    to stop people removing them, same way people like Audi use special screws
    to secure stuff just so you have to pay the dealer to do it.
  16. Yorkshire Tyke
    I thought as much!! B**tards!! It isn't anything that requires a bike mechanic it just takes a while, is this a theme Honda are sticking with from 2010 onwards then? The pillion pegs on my '08 600RR came off in a jiffy!!!
  17. Muffking
    It always worries me having to, leave the bike balanced like that when both wheels have to be off at the same time, so i use an ABBA stand now :-0
  18. Jollygiant
    Jollygiant Member
    Get the pillion adapters from rexpeed. That way you can take them on and off nice quick.
  19. phantom
    what way does that work then?
  20. Jollygiant
    Jollygiant Member
    They bolt onto where the pillion pegs do on the inside of the subframe then you can bolt the pillion pegs onto the bit that hangs below the subframe. Circled it for you below.
    That make sense ?
    #1420 Jollygiant, Jan 20, 2013
