What OIL are you running ?
Discussion in 'Maintenance' started by BladeWitch, Aug 3, 2013.
  1. RedBull
    RedBull Member
    Ditto - That's "same here" for all those people who don't know what "ditto" is...lol
    Perhaps it would have been easier to type " same here"
  2. phantom
    phantom Active Member
    if fully synth are causing problems with blades I would say there is something wrong
    with them as a lot of bikes state on their owners manual to use fully synth.the whole
    clutch slip myth was formed when people put fully synth car oil into their bikes which
    is the total wrong grade.on another totally different note I invalidate my car
    warranty if I put semi synth into it lol.
  3. Remal
    same here
  4. Julian
    Julian Active Member
    jeez my head is shredded after reading this and i'm still none the wiser :confused: I am currently running Castrol 1 10w 30 semi synth and I have noticed the gearbox is a lot more clunky than it ever was before, so what next ? 10w 40 semi synth or something entirely different ?
  5. phantom
    10w 30 fully synth :p
  6. t0m541
    t0m541 Senior Member
    Mazola cooking oil, not only does the bike look good it smells great :) like chips :)
  7. fecklessijit
    fecklessijit Active Member
    After lots of vibration and clunky gearbox in summer months I changed to 20w 40. Much better and runs cooler. Slightly. Anyone else experienced the vibration effect? It was definitely the oil as I changed chain, checked alignment, sprocket change, removed sprocket play, and nothing worked. Oil change ( only done 900 miles since last oil change) cured it instantly. Unless the last honda dealer used chip fat strained through a pair of old tights?? Could happen?
  8. Alfie
    Alfie Active Member
    I'm using Motul at the minute but I'm not to sure I like it!! The garage put it in my bike when I took it for a service, I use a Honda filter as well.
    Next service I will be going back to Castrol I think?????
  9. AABIKER
    AABIKER Member
    Silkolene Comp 4 - gr8 oil
  10. phantom
    never had vibration from mine,
    was 10w 30 semi in it to start with.
  11. wedgiewolves#223
    wedgiewolves#223 God Like
    Castrol power racing fully synthetic 10w 30 gold tub always used this in my blades never had a issue
  12. fecklessijit
    Just put a thicker oil in unless you know that the oil is good already. It cured my vibration instantly. Oil was piss weak. Like water. Seems to have just broken down the properties too quickly or like I say the Honda dealer was using chip fat. It's a cheap solution to get rid of what may be causing your issues. 20 40 is still recommended in blade.
  13. Scott
    Scott Active Member
    Can't go wrong with castrol I'd say.
    What filters do you use ?
  14. Alfie
    Alfie Active Member
    I was not to bothered abou using Motul as I thought it was a good oil!! I looked up on it and it had ok reviews, the IOM TT Legends team run it in their bikes lol NOw theer is that little bit of dought in my already minced heed
  15. HRCTrev09
    HRCTrev09 Well-Known Member
    I don't rate Castrol at all! It's only recommended due to sponsorship deal it's not the best oil out there! I found it caused vibration and poor gear change!
    I've always used Silkolene Pro4 fully synthetic and thot I'd try Castrol but now back to Silkolene it more expensive but definitely the best I've tried the bike's way smoother and gear change is slick :)
    10w30 is what I use! But 10w40 won't do any harm.
    #115 HRCTrev09, Nov 7, 2013
  16. Alblade
    Alblade God Like
    Think I am on halfords fully synthetic. Bike not used too much either
  17. Alblade
    Alblade God Like
    Have also used heine gerricks own stuff, motul, castrol etc. I forget but in 70k I have used a fair mixture with no issues!
  18. Skippy79
    Skippy79 Active Member
  19. Dec
    Dec Active Member
    Best deal I could find for Silkolene Pro 4 Energy 10W-30 Synthetic Oil
    Used to get white crap on the filler cap on my BMW F800 and was worried about a gasket issue.
    My specialist mech told me the oil used by Motorrad (no idea) may be giving off slight condensation (hence the white film) and that he uses Silkolene that will never do this and he considers to be the best.
    Experience was much better all round after being serviced with this stuff.
  20. Scott
    Scott Active Member
    Genuine filters or hiflow/k an n ?
