What Tyre Pressures do you Run ?
Discussion in 'Maintenance' started by BladeWitch, Sep 8, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I'm going out today for a spirited ride round the moors with my dad, gonna try 33 f&r on the rs2s will update later!
  2. sinewave
    Nearly 6:30pm!
    Hope he aint Binned it! :eek:
    (Again!) ;)
  3. Dave V
    Dave V Elite Member
    32/36 road, 30/28 track
  4. Yorkshire Tyke
    Now now sine!! Don't be a bitch!!! :) I'm fine, so is the blade. And ended up running 34 F 36 R and it felt lovely.
  5. BladeRR8
    BladeRR8 Active Member
    34/34 on a hot day on road
    34/38 on an autumn day on road
    30/28 sunny track day
  6. Yorkshire Tyke
    Ha does that mean you only do sunny trackdays???
  7. sinewave
    Don't think I could run my rear higher than the front young Tyke?
  8. Yorkshire Tyke
    Yeah thats what I thought but was reading up on the RS2 earlier and it was suggested that pressure, tried it- spot on. Guess you've never touched manufacturer suggestions then??? 36 F 42 R??
    OMG!!!!!!
  9. The.kickboxer
    The.kickboxer Active Member
    Weight is defiantly mass, the force is gravity and centrifugal force while cornering, the force will be greater if the weight is higher. Huge calculations concerning gravity would be needed to conclude this argument.
  10. abv
    abv Active Member
    Weight is not mass. A 1 Kg mass would have a different weight on the moon as the force of gravity is less. Weight is the force of gravity and should be measured in Newtons.
  11. travellingkiwi
    travellingkiwi Active Member
    While we're being pedantic, it's 1kg... Not 1Kg... Kg would be Kelvin-grammes... Not really a common unit :) It's a lower case k for kilo prefix...
    The rest is spot on though :)
    H
